turbotankshane
- Aug 3, 2010
b230ft, microsquirt v3, 91 s10
I'm using a zex wet kit on the b230ft in my s10, and wiring is simple: red wire to 12v arming voltage, black wire to ground, white wire to tps signal. The box is looking for 5v to tell it the throttle is wide open to switch the kit on.
So, looking at nitrous control in my tunerstudio, it only gives me the option of the FIDLE pin for a single stage output, and IIRC that pin pulls the circuit low, and I need to put 5v to the trigger wire to be able to control the nitrous box with ms. I'm currently using the FIDLE circuit for boost control, but I plan to switch boost control to the TACHOUT circuit if need be.
The first thought I had would be to use the FIDLE circuit to activate a relay, which would send the +5v sensor supply voltage to the box. I know it needs to see 5v to trigger, but I'm not sure if sending it 12v would cause problems.
Ideas?
Is there another circuit I can program to send out 5v when nitrous activates?
Ideas?
