BenBlue&Betty
- Nov 20, 2012
- Tulsa OK (for now)
Acquired an 84GLT TURBO from others who'd apparently dogged it, without regular maintenance. At this point, I've replaced rotting K-jet harness, done tune-up, etc etc.
After SEVERAL attempts, I get it to stay running... But ONLY by pushing accelerator to keep it at about 1800 RPM. Foot off gas... dies. Now, I've followed procedures to check constant idle system... All (power,throttle switch, temp sender, air valve) check out.
So, following service procedures, I tried another CIS computer. No improvement. Two baffling responses: while shorting wires to CIS computer to imitate cold engine, it high idles... But not at the prescribed 1600-2400 RPM, but at 3000-3500! Also, once... After doing that, I plugged the connectors back into computer and the car actually ran & drove PERFECTLY... For about two hours, then went right back to dying.
Any one shed light on this weirdness?
