FarAway
- Dec 31, 2016
- Estonia, P?rnu
Hi guys,
I have big problem because i changed my ecu and now the fuel injectors spray fuel even then i put ignition on.
I Changed ecu because off that:
With old ecu car runs but not going over 2000rpm. Oil smells petrol already then. Old ecu was bosch 0 280 000 946 and new is 0 280 000 954. Is it may this be the problem?
Im using stock turbo bosch injectors. If i spray brake cleaner into the intake, car will start. So it got spark.
What to check or do next?
