hey guys,
i'm working on a b204GT. Took it completely apart, changed what needed to be changed and i (hope i'm) almost done now.
poured new oil in, hooked up a drill to the oil pump to prime and started getting the oil everywhere. fixed some small leaks (forgot to put new copper rings on the turbo fittings) and i have oil in alle the places it needs to be now (my cam cover is off, so i can see it comming up). Only problem, I keep getting air bubbles every now and then. Really small ones. 95-99% oil, 5-1% air. I've been running the pump for some time now; but they just keep comming.
Only thing i could think of what could be causing this is a bad O ring (number 15 in this link
should i look into it, or just ignore the tiny bit of air
