S
smokeyfan1000
Guest
I wondered if this would work 3 years ago, I too try to think out of the box and try things that I have not seen before and or work with what ya got and a tight budget. BRAVO! Simply BRAVO. The only thing that worries me about this is: I have(and others according to IPD) broken 2 end links on 2 Volvos with the 25mm IPD swaybars.Two sway bars has GOT to be more stress on the swaybar end link than set of 1 IPD25mm sways. Not dissing your set-up here, not at all, it is very good thinking IMHO. Just really think a bigger diameter(not much room to increase diameter on swaybar end of EL),so maybe grade 8 material? Please consider upgrading your end link & make it stronger. I know from personal experience, when end link breaks in the curve you have "thrown" the car in, it gets SCARY real quick!! As far as pulling inside wheel off pavement, my 25 mm IPD sways would take enough weight off inside rear tire ,as to make spinning VERY easy in corner, and this was with 79 245 B21(with 500,000+ miles on engine) normally aspirated engine, so you may pull wheel of ground with this set up, rear anyway. This is really cool, because I thought it would work, when I was thinking of it. Did not know it had been done already!! It is "Marvelous,Simply Marvelous"!! You deserve a standing ovation in my book!! Dave Barton too, I suppose. I got 3 sets of stock sways,hhmmmm. I really like this idea, Aspirator!! Really good write up & pics too!
