davidmacq
Bored Member
- Feb 17, 2003
- Clarksville, TN
So with the high lift in this cam...do you need new valves? Grind valves shorter? Shim kit has nothing that fits? Bad cam...or is typical?
installed mine with out a hitch other than it needed the valves to be shimmed. it was weird but more needed to be added the valves were loud.....VERY LOUD.
I had access to a shim kit it had the larger ones that worked for me.
perhaps I should upgrade to bigger and slightly longer valves?
