Old 07-17-2019, 04:32 PM   #1
Tfrasca
Tfrasca's Avatar
Default 140 headlight bucket compatibility
Simple question: are early (1968) headlight buckets the same as late (1973) ones? From photos, they look identical. I'm swapping a later grill onto my '68 and I'm not sure if I need to get the headlight buckets.
I'm looking at you, Redwood Chair, Planetman, etc...
Old 07-17-2019, 04:52 PM   #2
There's an early headlight bucket setup that uses a one piece metal bulb retainer that looks like this but it updates to the late style with 3 plastic clips that was used on all later 140's.
Old 07-17-2019, 05:14 PM   #3
Tfrasca
Tfrasca's Avatar
Ok, I think I have the early ones. It's got that piece in your photo, which attaches with three nuts.
Any idea whether I could use the early buckets with a later grill? I would think they'd all be the same, dimensionally.
Old 07-17-2019, 05:44 PM   #4
The early setup updates to the late one so you should be able to use either one. The adjusting screws are even the same.
Old 07-17-2019, 06:08 PM   #5
vwbusman66
Eisen-Stein
vwbusman66's Avatar
But why?
1971 142 DD/beater/fake racecar
2011 Jetta Sportwagen 2.5/5 speed
Old 07-17-2019, 06:14 PM   #6
Tfrasca
Tfrasca's Avatar
Perfect, thanks.
Old 07-17-2019, 06:15 PM   #7
Tfrasca
Tfrasca's Avatar
Originally Posted by vwbusman66 View Post
But why?
Sick of the silver grill, and I like the way that later one looks without the big turn signals on the sides.
Old 07-17-2019, 07:03 PM   #8
sksmith
sksmith's Avatar
I agree with you!
Steve
