Old 04-14-2008, 07:34 PM   #1
Patdon10
Patdon10's Avatar
Default Broken tailgate wire
Anyone know what this goes to?
My rear squirters don't work anymore. Could this be why?
The 245 Restoration.
http://forums.turbobricks.com/showthread.php?t=132952
Buyer/Seller Feedback
http://forums.turbobricks.com/showth...light=Patdon10
Originally Posted by adrianpike View Post
You cannot reduce a Volvo's value, as they're already worthless.
Patdon10 is offline   Reply With Quote
Old 04-14-2008, 07:38 PM   #2
orie
Doctor Who
orie's Avatar
Yep, that's why. Typical breakdown of the wires in there.
You will eventually lose the rear wiper, window defroster and finally the plate lights, which will get you pulled over. I simply bypassed them inside the trunk door for cheap+quickness, but i believe IPD (www.ipdusa.com) sells a kit to repair this. It's kinda a pita to feed the wires through.
orie is offline   Reply With Quote
Old 04-14-2008, 07:39 PM   #3
Patdon10
Patdon10's Avatar
Orie, I love you dude.
You know everything.
Old 04-14-2008, 07:40 PM   #4
orie
Doctor Who
orie's Avatar
Found it...
http://www.ipdusa.com/Volvo-200/Exte...p-69-259-1320/
Old 04-14-2008, 07:42 PM   #5
500dollar744ti
still rides with MrDoug
500dollar744ti's Avatar
those things go bad all the time, most people wait until the tag lights stop working and they get pulled over/ticketed before fixing it.
-Matt
1989 Volvo 744T- 16v turbo, '94 FD-block, RSI pistons/rods, GT35R, Tial 38mm, RFL, MSnS-E, DSM spark, 100lb Delphis, 4.6 springs, Bondo header, Heebspeed intake, Q45 90mm TB, Bosch 044 FP, 12x24x3 ebayIC, w/c t5, Clutchnet 4puck/PP, 4.10 G80, IPD sways, 960 brakes.
1998 Volvo S70 T5m- Stock, 229k
1998 Jeep Cherokee XJ- Stock, 154k
1983 Ford F150- '89 5.0 H.O, C6/4x4, F+R LSD 4.10, 7" lift, 35s.
1990 Cobia San Marino 225 ECS- MCM 350 Mag, GM Bowtie Intake, HR-Titan 19p.
500dollar744ti is offline   Reply With Quote
Old 04-14-2008, 07:43 PM   #6
orie
Doctor Who
orie's Avatar
Oh hey, did you mean squirter's or the actual wiper going, i might have mis-interpreted by being a lazy ass and reading too quickly. If it's just the water sprayer not working, you could have a bad pump up front, or the water line that runs to the rear sprayer is broken. Easiest to just pull the line in the engine compartment and have someone push the sprayer button, see if it sprays. If it does, check the line and make sure the sprayer isn't clogged (it snaps on/off, carefully!) But that severed wire is still the beginnings of what I mentioned above.
Old 04-14-2008, 07:44 PM   #7
orie
Doctor Who
orie's Avatar
Thanks man! I try to spread the knowledge where i can. There are others here much more knowledgeable than I, however.
Old 05-29-2008, 02:08 AM   #8
Nerher
Note to anyone trying to repair the wires in question: I spent about 10 hours total trying to rewire without removing the tailgate or undoing the hinges at all, making new wires myself using some large-gauge primary wire and heat-shrink tubing to bind them together and protect my splice-connections. I got the left side done, and the right side is impossible. Just go ahead and pull the tailgate off, it will save you a lot of time, pain, and general frustration. Plus, if your ground wire is broken... you can't do anything about it without undoing the hinge bolts.
Nerher is offline   Reply With Quote
Old 05-29-2008, 02:59 AM   #9
blarf
blarf's Avatar
You don't need to pull the tailgate off if you don't route the wires through the hinge.
Manuals moved here: http://gaz.inferiorhumanorgans.com/greenbook/
blarf is offline   Reply With Quote
Old 05-29-2008, 03:18 AM   #10
DaButcher
Do a Burnout!
DaButcher's Avatar
I have lost just my rear wiper.
However, at first, when I bought the car, it would work.
It would however not park, eg. it would park where it was, when I turned it off.
Then, one day, no wiper :(
Everything else works though! Also, if I squirt water on the rear window, no wiper function.
I guess this means defective wiring, as the front wipers work?
They use the same relay, right?
ps. I have checked my fusebox :-)
DaButcher is offline   Reply With Quote
Old 05-29-2008, 03:52 AM   #11
blarf
blarf's Avatar
Bad wiring (at the tailgate harness) is certainly easy enough to check with a multimeter.
Old 05-29-2008, 08:04 PM   #12
84 Blue 240
84 Blue 240's Avatar
Mine is bad too...but although broken clear in half, they make contact when it is closed and everything works...for now (been that way for months). I love my Volvo...things break but never stop working all together.
84 Blue 240 is offline   Reply With Quote
Old 05-29-2008, 11:13 PM   #13
dalek
Benchracer Tribe
dalek's Avatar
Twist the wires together using a drill before installing so to make them less eager to snap.
Feedback!
Old 07-02-2019, 11:58 AM   #14
jim_hoyland
Is there a good step by step video or guide to repair the wires for the wiper in my 240 wagon.
jim_hoyland is offline   Reply With Quote
Old 07-02-2019, 12:03 PM   #15
JohnMc
JohnMc's Avatar
Nike: Just Do It!
Get a helper to help wrangle the hatch - it's surprisingly heavy and awkward when unbolted.
Carefully undo the rear corners of the headliner - the fabric (should be, lol 30 years old now) somewhat stretchy and it is sewn to a plastic lip that fits into a slot. Just sort of pull it toward the edges to release that lip.
Then unplug the wires, on both sides, and unbolt the hinges, pull the wires out, remove the hatch. Unbolt the hinges from the hatch and fish the old wires out of the sides. That's the hardest part (for me anyhow) - there's not a whole lot of room to spare in there. Then hinge back on the door, and then back onto the car.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 07-02-2019, 04:15 PM   #16
jim_hoyland
That’s very helpful, thank you.
Am I correct that there are two Seperate harnessed ? I ordered the pass side harness from Swedish arparts.com? Didn’t see anything for drivers side, but one of those wire is broken too.
And, are the hinge bolts inside under the headliner ?
Old 07-02-2019, 04:22 PM   #17
IansPlatinum
IansPlatinum's Avatar
The harness does not come with the black wire that you are seeing. That wire is a ground between each side of the hinge... effectively it grounds the hinge and tailgate. Get some high quality copper wire for the black ground wire. I'm about to do the repair myself too.
and yes there are two separate harnesses. They're both available from volvo @ $50 a pop. Supposed to last longer than the swedish car parts ones, something about the wire being specialty built for repeat bending.
Here's the ground wire
'96 854 Platinum - "Trusty"
'92 245 - "Boat"
'71 145 - "Rusty"
Previous:
'73 1800es - "Sunny"
'92 940T
'98 S70 T5
'99 S70 GLT
Old 07-02-2019, 04:25 PM   #18
JohnMc
JohnMc's Avatar
Yes, two harnesses, one on each side. Certainly not one of Volvo's finest engineering feats. The bolts are on the underside of the roof, clearly visible when the headliner is out of the way.
Left and right harnesses: https://www.ipdusa.com/catalog.asp?n...ailgate+wiring
Use a wire or strong cord and tie to one end of the old harness before pulling it out of the hatch side, then use that to pull the new harness through. Take a quick pic of all wires on either end before undoing anything in case you're not clear on reassembly.
Another nice thing to replace while you have it apart are the gaskets under the hinges: https://www.ipdusa.com/catalog.asp?n...e+hinge+gasket
Also, I had a peculiarly hard time with the rear sprayer nozzle on mine, the rubber hose just wouldn't come off the nozzle on the hatch. *REALLY* stuck on there, like it was glued in place.
Old 07-02-2019, 04:32 PM   #19
sbabbs
sbabbs's Avatar
I do one side at a time instead of unbolting both hinges. Makes it easier to hold the rear door up. I use a movie grip C-stand for that. Take the cylinders that hold the door up off first.
1995 940 White racing wagoon. T25 .64 a/r m90 to put in
Old 07-02-2019, 04:35 PM   #20
JohnMc
JohnMc's Avatar
/\ /\ /\ You'r making me thing I did it the hard way - taking the whole hatch off and replacing the wires, then bolting the whole thing back on.
Old 07-02-2019, 06:16 PM   #21
jim_hoyland
More good information ! I went to the IPDUSA website as suggested; of those harnesses show, which two should I order ? And, is the driver side harness a mirror image of the pass side ? (Same)
Old 07-02-2019, 07:49 PM   #22
JohnMc
JohnMc's Avatar
They are different side to side. And there's a -85 and an 85+ version as well.
Old 07-02-2019, 07:58 PM   #23
bobxyz
bobxyz's Avatar
IPD also has instructions in a .pdf with black and white pictures. Read through the part descriptions and it will say if left side harness or right side is the one for the wiper but, since you're going to be there anyway, replace both. If your wagon is 83/84/85, you'll want to peek at your connectors first to order the correct style replacements.
Old 07-02-2019, 08:10 PM   #24
TestPoint
TestPoint's Avatar
Default 245 hatch wiring replacement
The hatch is conveniently about 6' high when raised without the gas cylinder. A step ladder in the middle makes removal of one side at a time easy. The OEM wire are fine strand like welding cable to withstand a thousand flexes. The aftermarket ones are not and their lifetime is much shorter.
If the OEM harness has never been worked on there is enough slack to pull some through and splice the broken fine wire outside of the hinge area. My right side has sacrificed slack twice but now needs a transplant.
Don't be afraid to gently pull the headliner back and out of the crimped track. I have had my 37 year old liner out many times without damage.
I have no intention of replacing the harness wire with aftermarket wire that is going to fail within my lifetime (I hope). I am going to use some of the several feet of unmolested fine OEM wire to the lock/light area to splice into the IPD aftermarket harness at the hinge with enough slack on both sides to repair it a couple more times.
The left side has only failed once so I figure I have a little slack to go on that side.
I purchased this car new in 1982 and plan on being buried in it.
Ford V8 Conversion Manual -
Old 07-02-2019, 09:44 PM   #25
cleanflametrap
cleanflametrap's Avatar
Originally Posted by TestPoint View Post
The hatch is conveniently about 6' high when raised without the gas cylinder. A step ladder in the middle makes removal of one side at a time easy. ...
Pic is small b/c when it was taken, bits on the internet were costly and slow moving.
-Art
