Old 04-08-2011, 01:54 PM   #101
M.H. Yount
M.H. Yount's Avatar
This is the lighting tutorial I used as a basis for doing my upgrade. This entire site should be bookmarked for anyone that's serious about lighting. http://www.danielsternlighting.com/t...ys/relays.html
Old 04-08-2011, 02:43 PM   #102
Cameron
ドクターマリオ
Cameron's Avatar
Originally Posted by SLOTh_244 View Post
Cam-
please write a tutorial on the headlights... pretty please :-)
-everyone everywhere
Bingo. That's the exact article I used for the basis of my redo of the circuit. The only variation I adapted for mine, for simplicity sake was to only use one relay, inserted between the switch and the step relay instead of 2 separate relays after the step relay (one for hi one for low) like in Daniel Stern's article. While my version won't be as 100% awesome as the Daniel Stern version, it's still solves a major issue with the stock system of running all the power through the headlight switch which adds a lot of resistance and is also a little dangerous in my opinion.
Originally Posted by mblue240 View Post
If you ever need a second set of hands please let me know...
Will do. None of it is really that complicated, just takes some thought and planning. I've learned that taking the time to draw out the circuit before you start tearing into things will help make the job easier.
Cameron is offline   Reply With Quote
Old 04-08-2011, 02:56 PM   #103
Tom Wiley
If your 'bay ends up looking like the VW you posted, I approve.
Tom Wiley is offline   Reply With Quote
Old 04-08-2011, 02:57 PM   #104
Cameron
ドクターマリオ
Cameron's Avatar
Well it won't have a Porsche motor, so prepare to be disappointed
Old 04-08-2011, 03:01 PM   #105
M.H. Yount
M.H. Yount's Avatar
I placed my relays (2 on each side - yeah, overboard) in the front most, lower corner of the fenderwell. From there it was easy to run the 'old' 12v+ wire from each headlight to be the 'trigger' of the relay. I put an audio style fuse-box on the passenger side fenderwell with an 8 ga wire/cable running to it from the alternator; 1 20A fuse for the headlights on each side (2 fuses); and then 10 ga wire from the fuse box to power up the relays. Built a separate harness out of 10ga (+ side and ground) and used the factory bulb plugs/terminals (they come apart for rewiring). With 55W high-output halogens on the low beam, and 100W on the two stand-alone high beams, it fries eggs at 50'. Well, sort of.
Old 04-08-2011, 03:01 PM   #106
Tom Wiley
I know what I meeeeeeeeaaaaaaaaaann.
Old 04-08-2011, 03:10 PM   #107
Karl Buchka
A nice way to get high quality, high capacity relays is to pull them from a newer car at the yard. Alex and I rewired my old 242 with all solid state 850 relays. It worked very well. This way you get nice stuff that's actually engineered and built to be installed in a car.
Old 04-08-2011, 04:24 PM   #108
M.H. Yount
M.H. Yount's Avatar
Yup - all 4 of mine (Bosch) came from previous cars/projects -- sittin' in the 'spares' box. Just need to be sure they're up to the task capacity-wise.
Old 04-08-2011, 04:48 PM   #109
euroshark
euroshark's Avatar
Love that front end... I can't wait to see where this goes.
euroshark is offline   Reply With Quote
Old 04-09-2011, 11:45 PM   #110
Cameron
ドクターマリオ
Cameron's Avatar
Old lump removed:
Old 04-10-2011, 02:43 AM   #111
doucheNozzle
doucheNozzle's Avatar
What's replacing it?
'93 944 T - #TrophyVo
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
Old 04-10-2011, 02:50 AM   #112
Cameron
ドクターマリオ
Cameron's Avatar
Hopes and/or dreams.
Old 04-10-2011, 02:50 AM   #113
RvolvoR
hamsters
Old 04-10-2011, 02:51 AM   #114
doucheNozzle
Sounds familiar.
Old 04-10-2011, 03:07 AM   #115
volvoboy67
volvoboy67's Avatar
Mr. Fusion
DD: 2004 GMC Yukon XL, lowered 4" Front, 6" Rear, staggered 20s, custom paint work, built engine and trans, just under 500HP.
Project DD: 1965 122s coupe, very lowered, bare shell resto with full custom paint, modded B18, M41 OD trans, staggered wheel and tire combo, lots of Dynamat.
Feedback here: http://forums.turbobricks.com/showthread.php?t=208560
volvoboy67 is offline   Reply With Quote
Old 04-10-2011, 03:31 AM   #116
Jerd
Jerd's Avatar
Old 04-10-2011, 05:52 AM   #117
Quin
ಠ_ಠ
Originally Posted by Jerd View Post
Old 04-10-2011, 11:17 AM   #118
morganpartee
Almost out of the Volvo game!
2011 Ford Ranger
1997 Miata, Supercharged
2002 Suzuki DRZ-400S
2013 Yamaha FZ6R
morganpartee is offline   Reply With Quote
Old 04-10-2011, 11:48 AM   #119
amerbritcan
Hnnnnnng
amerbritcan's Avatar
looool. I think quin has it though.
1990 745tic
1984 244DL (parts)
Originally Posted by My Mom
Get a bike
Poopie scissors
Old 04-10-2011, 01:02 PM   #120
Cameron
ドクターマリオ
Cameron's Avatar
Originally Posted by morganpartee View Post
Don't forget:
Old 04-10-2011, 01:04 PM   #121
Cameron
ドクターマリオ
Cameron's Avatar
Nah, only way I'd do V8 is if I could afford an LS9 crate motor.
Old 04-10-2011, 03:10 PM   #122
RvolvoR
Im not going to lie here...all of the blacked out stuff on the rear of the car makes it look really cheesy and cheap...should left the inset unpainted and chrome on the tails...
Old 04-10-2011, 03:22 PM   #123
amerbritcan
Hnnnnnng
Originally Posted by Cameron View Post
Don't forget:
I dunno who that is?
Old 04-10-2011, 03:23 PM   #124
Cameron
ドクターマリオ
Cameron's Avatar
A crutch holding up a hood doesn't? Different strokes for different folks. I'm styling the car the way I want it, just like you've styled yours the way you want it. You don't like the way mine looks and I don't like the way yours looks. Big deal - isn't that the point of building your own car
Old 04-10-2011, 03:23 PM   #125
Cameron
ドクターマリオ
Cameron's Avatar
Naaaaaaass!
