Old 04-14-2011, 09:08 AM   #176
Mattis
Mattis's Avatar
Originally Posted by Cameron View Post
Thanks Mattis
No problem, glad it arrived safe and sound.. was starting to worry a bit
Mattis is offline   Reply With Quote
Old 04-14-2011, 10:47 AM   #177
Cameron
ドクターマリオ
Cameron's Avatar
Originally Posted by Old Iron View Post
...consider automotive design!?! Idk
I don't think I'd last too long -- everything I'd design would looks like a 240
Me too -- it'll be a cool little detail for the car. I really like it because it's a genuine Volvo item that is era appropriate. Now I just need to do a nice cleaning on it and the matching Volvo emblem for the other side and give them a nice fresh finish.
Cameron is offline   Reply With Quote
Old 04-14-2011, 11:11 AM   #178
Old Iron
I Roll
Old Iron's Avatar
[QUOTE=Cameron;3721397]I don't think I'd last too long -- everything I'd design would looks like a 240 QUOTE]
Hahah that would be cool! Bring em' back!
Turbobricked
Originally Posted by Anonymous View Post
No sarcastic replies from Redwood Chair necessary
Old 04-15-2011, 11:53 AM   #179
Cameron
ドクターマリオ
Cameron's Avatar
Spent a little time in the garage last night working on it. Also did a lot of staring at the engine bay and rearranging things for the engine bay in my mind. Clearing up the vision for it I guess you could say
Derek had previously removed all the wiper stuff from the car as it was going to be a summer only car for him. Since I'll be reinstalling it all I pulled the wiper motor out of the box in the trunk and got it all cleaned up, painted, and bolted back down to the firewall -- sticky gooey seal and all.
Also got started on the hydraulic clutch conversion. Unbolted the old clutch pedal and bolted in the new 260 hydraulic clutch pedal clone I got from Tom Smith:
Then got the clutch master cylinder bolted in, which turns out kinda sucks when you're doing it yourself and have no one to hold the bolt head on one side of the firewall while you tighten the nut on the other. Got that attached to the pedal so that side of it is done.
I'm keeping the M46/flat flywheel combo in the car & I already have the hydraulic fork from a 740 and slave cylinder from 740 so I'll install those next. Just gotta figure out which release bearing to use with this combination. I might have to just order an M46 hydraulic clutch release bearing from a 740 and compare it to the early M46 one in there now. From the pictures they don't look too different at all, but I have no measurements so The early M46 I have has the early shaft with smaller spline count than the later M46, but as far as I know the diameter is the same so I don't see why the original M46 release bearing in there wouldn't work?
Old 04-15-2011, 12:10 PM   #180
Cameron
ドクターマリオ
Cameron's Avatar
Right after I finished typing that, these showed up at my desk
For reference, they're fresh seals for where the side tail lamp assemblies seal against the body on the outboard sides. #13 in the diagram:
Old 04-15-2011, 03:20 PM   #181
M.H. Yount
M.H. Yount's Avatar
New tail light seals = more matte black. Daddy likes.
Old 04-15-2011, 07:30 PM   #182
FatLobes
i think i spotted this bad boy at IPD, if so the rear looked clean
FatLobes is offline   Reply With Quote
Old 04-15-2011, 07:35 PM   #183
Cameron
ドクターマリオ
Cameron's Avatar
Well, it's in my garage with an empty engine bay at the moment... I bet you saw Bryan's 142. He has a white 142 he daily drives that he did the black back panel on too. I'd imagine that's the car you saw.
Old 04-15-2011, 08:05 PM   #184
You might (and probably will) hate me for this, but the motor is a no-go. I failed to realize that I'm moving to a garage-less apartment in less than two months
Old 04-15-2011, 10:17 PM   #185
Cameron
ドクターマリオ
Cameron's Avatar
Then to the scrapper it goes I guess. Anyone else want it?
Old 04-16-2011, 01:33 AM   #186
Cameron
ドクターマリオ
Cameron's Avatar
NOS butteryness that showed up in the mail today:
The "as-stealthy-as-it-gets" wiper motor install eluded to above:
The new clutch master placement -- just gotta unbolt the block off plate and it goes right on:
The hydro pedal mounted in the pedal box & attached:
Old 04-16-2011, 01:35 AM   #187
morganpartee
Did IPD buy out a random swedish part warehouse? I think this thread has more NOS crap than I've ever seen.
Almost out of the Volvo game!
2011 Ford Ranger
1997 Miata, Supercharged
2002 Suzuki DRZ-400S
2013 Yamaha FZ6R
morganpartee is offline   Reply With Quote
Old 04-16-2011, 02:37 AM   #188
Cameron
ドクターマリオ
Cameron's Avatar
Nope, just my Volvo sluethiness & some lucky deals is all.
Old 04-18-2011, 01:18 AM   #189
klr142
Turbo, what?
klr142's Avatar
Yes, we might be able to use it as a chumpcar motor? We still need to figure out how to mount an OHC engine, but that's the plan for October's race!
Car's looking awesome man! Do you expect to have it ready for IPDizzle's swap meet?
Old 04-18-2011, 01:23 AM   #190
860volvo244
860volvo244's Avatar
very nice job cleaning up those wheels they look awsome
94 945 peeling paint lowered on billy HDS. header 3.5dp w/ wideband 3in stealth exhaust. Browntops 3in amm Overkilled 15g 18psi soon to be holset. Enem cam. NPR. Injectoids. Wasted spark Borbet type a.
84 244GL - Brown on Brown - LH2.2, B23 flat tops, K cam with upgraded valvesprings. Manual Steering, AC Delete, BnGs with billy HDs, 25/25, chassis bracing, WCt5 trans
860volvo244 is offline   Reply With Quote
Old 04-18-2011, 02:02 AM   #191
Just had a chat with the in-laws. They cleared out some room so I can take it after all! Provided Kyle doesn't have new dibs on it now, that is
Old 04-18-2011, 02:24 AM   #192
Trevor+
Volvo Friends
Trevor+'s Avatar
Kyle has dibs because racecar.
Originally Posted by hathos View Post
GODDAMNIT, IT WASN'T RATTLE CANNED. IT WAS EARL SCHEIBED AND *MATCHED* TO A RATTLE CAN
Trevor+ is offline   Reply With Quote
Old 04-18-2011, 01:06 PM   #193
He wants to put a B21 in a 142. It will never work. The B21 wasn't installed there from the factory so there is no way to make it fit.
/Brickboard
Old 04-18-2011, 01:57 PM   #194
WeezilUSA
WeezilUSA's Avatar
/Brickboard
I haz 142 w/ b21 in it...
1983 242 ICSCC GP Race Car
WeezilUSA is offline   Reply With Quote
Old 04-18-2011, 07:04 PM   #195
klr142
Turbo, what?
klr142's Avatar
Harald, you can have it. We're getting a motor/trans combo from Taylor.
Old 04-19-2011, 02:55 PM   #196
Cameron
ドクターマリオ
Cameron's Avatar
Thanks! Dunno about for garage sale. I'd really like to have it driving by then. Need to call Bryan at M&B and bug him about my motor parts that he's had since January I guess.
Thanks!
I'd say Trevor is right, but....
Guess they don't need it
Old 04-19-2011, 03:04 PM   #197
That motor/trans combo wouldn't happen to be that 2.5L penta motor now, would it?
Thanks for letting me know, Kyle
Old 04-19-2011, 04:39 PM   #198
Cameron
ドクターマリオ
Cameron's Avatar
It would not.
Edit: Just realized you probably directed that comment to Kyle. So nevermind!
Old 04-21-2011, 02:12 PM   #199
valvesprung
valvesprung's Avatar
Love this so far man...
Jordan Green
HM Motorsports
'00 Audi S4 mine '98 XC70 wifey ride
valvesprung is offline   Reply With Quote
Old 04-21-2011, 02:52 PM   #200
Cameron
ドクターマリオ
Cameron's Avatar
Thanks!
I got distracted by a deck project last weekend.
So because of that I didn't do much on the car. Got back to it last night though and got more of the headlight and parking light stuff reinstalled. Got the switch back in, the harness for it untangled and got it all hooked up to the power block and new relay setup. Also fished out the wiper motor harness and shrinkwrapped it at the connector to tidy it up. Just need to grab a small grommet and drill a hole in the firewall right under the motor to push the wires through. I also reinstalled the firewall grommets I removed when painting the bay in all the holes that will remain unused. Oh, and also ordered all the clutch line stuff for the hydraulic conversion from Volvo.
