Old 07-04-2019, 03:25 AM   #351
Alex Buchka
8 cylinders
Alex Buchka's Avatar
Gah-dang.
If I didn't know better I'd say that this is the product of a rocket surgeon.
Thanks! I got out of the rocket surgery game years ago though.
Originally Posted by Hank Scorpio View Post
I REALLY want a ride in this. Badly.
Great job you guys
Thanks Doug, you know where to find it. I'm planning on going to the VCOA national meet in SLO this September, should have it much more sorted by then.
Originally Posted by dbarton View Post
It looks very similar to the one in Peggen Anderson's Group A Nordica car.
Dave B
That's definitely the 100% unobtanium 1031 version. I have the slightly more approachable, and arguably worse, 1030 diff housing that was bolted on to various stock 240's in the early 80's.
Been driving it around the last few days, tinkering with the calibration a lot. E-Throttle is awesome and lets you do all kinds of fun stuff. The ITB's flow a lot of air at miniscule throttle angles which makes tip-in driveability and smooth take offs from a stop pretty poor. To solve this I've been dicking around with blending in airflow from the idle valve. BMW actually did this from the factory on the E46 M3 so the idle valve is massively oversized for just idle control. At 5% pedal I have 100% DC on the idle valve but only command 1% on the throttle plate. This makes the engine really smooth on take off and allows for smooth cruising at constant speed. I still have some jerking when transitioning from drive to overrun and vice-versa but I think I can smooth that last little bit with timing adjustments.
Old 07-04-2019, 04:19 PM   #352
Quin
ಠ_ಠ
cool.
Old 07-20-2019, 12:06 PM   #353
JW240
All idiot, no savant
Don't know what to say or add, I'm very impressed.
Very very nice build guys!
240 | 1991 | 341K Km | B230F+T | Cosworth T3 60/63 | M90 | TrueTrack
940 | 1992 | B230FB
Old 07-22-2019, 09:00 AM   #354
dbarton
Dejected by Volvo
dbarton's Avatar
Ditched the belt driven power steering pump and installed a cooler and an electro-hydraulic unit from an R53 BMW Mini. Less assist but no more squealing pump and nuked fluid.
I'm very curious about this steering pump installation.
Is it mounted under the front of the car? Do you happen to have a pic of it showing where it's mounted, not quite so close-up?
I really like the idea of ditching the belt driven pump.
Dave
'84 242ti, owned since 2003. Always garaged since brand new. Old-school rounds because. B21FT, SDS EFI/IGN, TD04HL-15G, T5Z trans with 0.73 OD, 3.91 diff with unmodified G80.
Volvo Seeks Divorce from Volvo Enthusiast Community: www.prancingmoose.com/#novolvo
Alternator Idler Pulley Project: https://forums.turbobricks.com/showthread.php?t=350085
Old 07-22-2019, 01:46 PM   #355
Trevor+
Volvo Friends
Trevor+'s Avatar
Dave
You could power it with a Honda generator installed in the trunk.
Originally Posted by hathos View Post
GODDAMNIT, IT WASN'T RATTLE CANNED. IT WAS EARL SCHEIBED AND *MATCHED* TO A RATTLE CAN
Trevor+ is offline   Reply With Quote
Old 07-22-2019, 02:02 PM   #356
I appreciate the polymer coated SS hose and use of P clamps.
Old 07-22-2019, 02:58 PM   #357
dbarton
Dejected by Volvo
dbarton's Avatar
So there are opinions saying it uses way too many amps?
Dave
Old 07-22-2019, 08:45 PM   #358
Alex Buchka
8 cylinders
Thanks man!
Dave
I'll get some more shots tonight after work that show the location and bracket more clearly. The level of steering assist is definitely lower than having a belt driven pump but I'm not bothered by it at all.
Judicious use of p-clamps is the only way to go.
Old 07-23-2019, 08:51 PM   #359
dbarton
Dejected by Volvo
dbarton's Avatar
Dave
Wondering what puts more drag on the motor. Spinning a belt PS pump or supplying the power to spin the Mini pump.
Old 07-23-2019, 09:06 PM   #360
sksmith
sksmith's Avatar
Amps can be increased with a larger alternator and corresponding wiring upgrade.
Spinning another accessory using engine power will always rob more engine power. Even with a larger alternator, since you having less rotating accessories.
Steve
Old 07-27-2019, 05:49 PM   #361
sim
Mere Drab Mob
sim's Avatar
Steve
This assertion smells funny.
A well engineered belt drive can be 98% efficient.
80% efficiency is a good number for both and alternator and a small DC motor.
Considering that the alternator is also belt driven you have, optimistically,
98% x 80% x 80% or 63% efficiency if you generate electricity and then turn a
shaft with it in a typical automotive situation.
Electric power steering pumps can be more efficient than a belt driven pump, but
for other reasons, predominantly that assist is only needed when actually turning,
and the assist required is inversely proportional to road speed.
Belt driven loads need to be able to cope with a wide range of input speeds, and this
leads to inefficiency also.
Comparing watts to watts, it is more efficient to drive a hydraulic pump directly
from the crank versus generating electricity from the crank then driving the pump
from an electric motor.
I have a Volvo with some half-done, homemade crap in it.
http://forums.turbobricks.com/showthread.php?t=244534
sim is offline   Reply With Quote
Old 07-29-2019, 10:26 AM   #362
dbarton
Dejected by Volvo
dbarton's Avatar
It all seems pretty academic to me until someone actually starts measuring amps used to run the electric pump, etc. But in quick google searches I'm finding info that suggests dyno testing on engines with belt driven PS pumps show it can lose as much as 8 ft lbs at peak torque.
Dave B
Old 07-29-2019, 12:16 PM   #363
OEMs did it for packaging reasons. The cool thing for efficiency is now EPAS.
Old 07-29-2019, 03:03 PM   #364
dbarton
Dejected by Volvo
dbarton's Avatar
For those who have manual racks.
Dave
Old 07-29-2019, 03:34 PM   #365
Dave
Thats not true at all. Plenty of people with power racks are still using EPAS
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 07-30-2019, 08:12 AM   #366
dbarton
Dejected by Volvo
dbarton's Avatar
I had no idea about that. I want to see a 240 with that.
Old 07-30-2019, 09:35 PM   #367
Stiggy Pop
Stiggy Pop's Avatar
I’m interested to hear some more colored feedback after you’ve driven it a bit. I’ve not yet driven a car with any level of electric assist that had satisfactory steering feel. I haven’t driven a new 911 but all of the modern BMWs et al are number than the back of Lindsay Lohan’s throat on a Saturday night.
'79 242
943 pickup
Old 07-30-2019, 11:00 PM   #368
I like EPAS on my TSX and in the Fit back when I had that.
Old 08-13-2019, 04:48 AM   #369
Alex Buchka
8 cylinders
Pretty much exactly this. There is no efficiency to be gained from bolting on an electro-hydraulic pump and running it full blast all the time. It will, all things being equal, always use more power due to conversion losses. That being said, I didn't do this for any perceived efficiency benefit, it was only for packaging. The car has fairly heavy steering now which I am actually a bit ambivalent about, I have no need for effortless parking lot steering and feel at speed is about the same as before.
Exactly. We put a prius EPAS column in our E36 lemons race car. The thing kept nuking power steering pumps and tossing the serpentine belt. All we did was loop the lines on the rack and mount the column. The torsion bar isn't even locked out in the spool valve and it works great. Steering feel is slightly worse but it's not exactly razor sharp from the factory so
In preparation for dyno tuning I added some instrumentation to the car. I wanted exhaust gas temperature and fuel pressure monitoring in the ECU to make sure things weren't going pear shaped. Bought a Setra transducer on ebay and made a short M12 to D38999 jumper harness that connected to one of the spare I/O bulkhead connectors Karl set up on the engine harness.
I didn't get any pictures of the EGT probe work but the engine now has 8 K-type sensors on it. One for each cylinder, one in the collector, and one in the downpipe. I connected everything to an 8 channel thermocouple to CAN interface box from AEM. Apart from an intial SNAFU where I had to learn the hard way that the AEM box does not support grounded sensors, everything went together pretty smoothly.
I took last Friday off work to meet up with my ace calibrator friend Neel at a shop in the inland empire called Nine-11 Design. It's a high-end Porsche shop that graciously allowed an old Volvo to besmirch their Dynapack for a day.
The Dynapack absorber unit was a very tight fit on the passenger side of the car. While bolting up the hub adapter I was nervous about clearance but it just about fit.
Their cooling fan setup is highly optimized for air cooled Porsches so we had to be careful to keep temperatures in check. There just wasn't enough airflow to keep up with steady state operation above about 4000rpm so for everything after that we just did transient pulls from 2500 to redline.
The fuel map was already 90% good from road tuning so we focused on timing and boost control. From a baseline of 220whp at 8psi we ended at about 320whp and 325lbft of torque at 14psi. The day was cut short due to some scheduling conflicts with Neel so we ended it there. I'm going back in a few weeks to continue dialing in timing, boost control, and knock detection. There were no signs of detonation at 14psi so I'm confident the car is capable of 350whp or more on 91 octane pump gas.
I couldn't get the stupid embed function to work but here is a short clip I took of one of the pulls we did.
https://youtu.be/DeyrS2Kk1yY
Old 08-13-2019, 07:23 PM   #370
Great numbers!!!
Old 08-14-2019, 12:20 AM   #371
Vol242vo
Keep it clean...
Vol242vo's Avatar
Seriously!
Derek
1980 242
-Project Thread-
Follow on IG: @vol242vo
Old 08-14-2019, 11:42 AM   #372
Duder
Comes with a free Frogurt
Duder's Avatar
Probably making 365 - 375 at the flywheel right now. This thing scooted before, should be a rocket now. Will need to verify!
Old 08-14-2019, 12:09 PM   #373
Looking forward to the post describing accidental 4th gear wheelspin...assuming traction control hasn't been set up yet.
Old 08-16-2019, 01:04 AM   #374
Alex Buchka
8 cylinders
Thanks dudes! Pretty happy with the results so far. I'm confident the combination has considerably more power in it. Going to add some pressure sensors to the manifold and downpipe before the next session to keep an eye on total delta P across the engine and turbine.
The car still has a stupid open diff so it's a one tire fire party in 1st through 3rd. I don't think the engine in it's current state will ever have enough power for a 4th gear rolling burnout.
Old 10-07-2019, 01:29 AM   #375
Alex Buchka
8 cylinders
Kicking a bunch of cans down the street as usual so progress is slow.
Went to the VCOA national meet in San Luis Obispo a few weeks ago. To be quite honest I was a bit disappointed with the whole thing, the show wasn't organized all that well and the 240 showing was pretty lackluster. It was mostly stock pushrod cars which don't really blow my hair back all that much. Karl snapped this photo of my car next to Homer's sweet 5-cyl 244.
Making headway on the axle build, rotor hats and outer axle hub flanges are done and I 3D printed some male/female press tools to make brake backing plates. I think I got a little greedy with the punch radius on the dimples so they're not quite as defined as I would have liked but in general I'm pleased with how they came out.
Got the tab-and-slot bits for the axle tube welding fixture in. I think I got a friday afternoon waterjet operator on these since the slots are very tapered and undersized. Kind of annoying to have to file all the slots out, but such is life.
Wheels version 2 that were alluded to years ago now are finally getting some attention. The design is pretty much where I want it so I 3d printed a partial slice of the wheel center to check for caliper clearance and to verify offset. Going for a Ronal Turbo-esque design with BBS Motorsport 17" rim shells. The wheels will be 8" wide front and back.
