Old 07-03-2019, 08:07 AM   #1
bugjam1999
Default Swap speedo tone ring into early axle?
Hi all,
A question about adding a speedo sensor to an early axle that doesnít have one- can it be done?
I appreciate that swapping the axle complete is easier, but complete axles are getting harder to find in the uk, since more and more people are building big power 240s and breaking axles...
So- is the diff casing different? If not, could a speedo sensor tone ring be welded to the diff the same as a later one and then the diff cover swapped for a later one that has the sensor in it?
Even reading that back Iím thinking we should keep looking for a later axle, but since Iíve typed it all out- could it be done?
Alternatively Iím sure I saw a thread about swapping an lsd in where someone was saying they cut grooves into the diff carrier for a sensor to read- perhaps thatís the cheap and nasty way to achieve what weíre looking for?
Cheers
bugjam1999 is offline   Reply With Quote
Old 07-03-2019, 11:47 AM   #2
bobxyz
bobxyz's Avatar
What do you want the speedo sensor for? How many teeth, 12 or 48?
Old 07-03-2019, 12:13 PM   #3
bugjam1999
To provide a speed signal for 2.4lh and for a speedometer- the car is getting an m90, which doesnít have a speedo drive.
The internals of a later speedo will he swapped into the earlier cluster - another friend did this previously and I have pictures etc.
So 12 teeth.
Cheers
Old 07-03-2019, 01:52 PM   #4
bobxyz
bobxyz's Avatar
One other option I've seen mentioned, but haven't tried personally, is to use a front strut, hub, and VR sensor from a later model 240 with ABS. The ABS hub is 48 tooth, and uses a similar VR sensor as the rear differential. With this, you'd need the later model speedo (K40000 series), and would wire it to the ABS sensor instead of the diff. sensor.
Old 07-03-2019, 01:59 PM   #5
superboosted
You wish you had some..
superboosted's Avatar
I used my front hub when i swapped diffs, worked perfect unless airborn or locked up
-1990 Saab 900 Turbo convertible-
-1998 Saab 900 Turbo convertible-
-1999 Lexus LS400-
-2001 VW GTI 1.8T-
-2017 Jeep Wrangler-
-none are volvos-
Originally Posted by centason View Post
You may get detonation and the kool-aid man loves 940s
superboosted is offline   Reply With Quote
Old 07-04-2019, 07:44 AM   #6
bugjam1999
A good suggestion, thank you. Unfortunately finding abs struts in the uk is basically impossible, Iím not sure Iíve ever seen a set on eBay or advertised on a forum. If desperate Iím fairly sure we could rig up something - possibly putting a laser cut plate on the back of one of the hubs and building a bracket to locate a sensor in a suitable place? - but I think in summary weíll keep looking for an axle and swap it in complete.
Thanks for all your input.
Cheers
Old 07-04-2019, 08:29 AM   #7
white855T
I could source you a set of abs strut tubes/spindles, if you go that direction.
