Old 07-08-2019, 11:33 AM   #1
stick70
All the gauges
stick70's Avatar
Default 1993 960 Sunroof not opening
When I press the switch the motor will "thunk" like it wants to move, but the panel doesn't actually move. It does this for both directions on the switch.
Do these things have a cable that seizes up or something?
Old 07-08-2019, 01:02 PM   #2
nedc
Take the cover that houses the motor/gear off and lube everything. I had to do this on a 92 i bought many years ago and there were some teeny skeletons in there! No lie...I guess they were mice...weird. Anyway, after I cleaned and lubed everything, it worked.
nedc is offline   Reply With Quote
Old 07-08-2019, 03:07 PM   #3
stick70
All the gauges
stick70's Avatar
I'll try that, it's an easy enough first step if nothing else.
Old 07-11-2019, 03:57 PM   #4
jwernerny
jwernerny's Avatar
Once you get it moving, TriFlow the track. I did this a couple of months ago on both the '88 760 and '94 940T, and it made the sunroofs work much better.
TriFlow, for those who don't know, is a lubricant that uses Teflon (tm). It last a long time and really makes things run smooth. Always shake the can/bottle well before applying to the Teflon is in suspension. You can get it at Amazon. I'm not sure where else.
John Werner
* 1992 944T * 1988 764 GLE V6 * 2002 WRX Wagon (needs motor) * 2006 Honda Odyssey *
jwernerny is offline   Reply With Quote
Old 07-11-2019, 04:53 PM   #5
apachechef
Burnt Sierra Madre
unplug the harness and be glad it died in the closed position.
Sunroofs are the devil's work.
Dammit, Lummert.
Old 07-11-2019, 05:54 PM   #6
eeaves42
eeaves42's Avatar
YES! also there is no part to fix 960 sunroofs.
"never give up never surrender"
1989 Volvo 745 TIC
2006 Saab 9-3 2.0T Wagon
2015 Kia Sorento
Feedback
http://forums.turbobricks.com/showthread.php?t=205098&highlight=eeaves42
eeaves42 is offline   Reply With Quote
Old 07-15-2019, 10:37 PM   #7
Wren
Porkchop Sandwiches
Wren's Avatar
The best piece of advice regarding 2/7/9 sunroofs is once it's closed, disconnect the switch and leave it that way. You're opening a Pandora's box trying to get them sorted out.
Old 07-16-2019, 08:52 AM   #8
stick70
All the gauges
stick70's Avatar
The sunroof in my 240 was silicone sealed shut when I bought it, works fine now.
I'll get my spell book out.
I think I'll start by seeing if it works manually, then go from there. I'll keep y'all posted.
Old 07-16-2019, 09:25 AM   #9
propav8r
F*ck Edgar
propav8r's Avatar
Well if you can't fix it, there's always duct tape and trash bags.
Originally Posted by Hockey930
Jb welding tiny pieces of a fuse to the injectors seems to have worked perfectly
Originally Posted by Quin
i improved my life by just getting rid of my 940
nipple farts
My Project
K-Jet to Megasquirt Article
Old 07-16-2019, 09:34 AM   #10
stick70
All the gauges
stick70's Avatar
Plan E: Copious amounts of bondo and silver rustoleum.
Old 07-16-2019, 08:09 PM   #11
stick70
All the gauges
stick70's Avatar
Well it's jammed up pretty good. Confirmed the motor works fine, and I can't get the screwdriver to budge it manually. Cables locked up or is there another common failure point?
Old 07-16-2019, 09:27 PM   #12
slow240
Home Schooled
slow240's Avatar
This sounds just like the sunroof in my 780. Would be kinda cool if it worked....
I'll polish your face
Old 07-17-2019, 08:57 AM   #13
stick70
All the gauges
stick70's Avatar
I think I'm just going to keep an eye out for a glass one with a headliner to swap in. The right cable is available new but the left is NLA.
Old 07-17-2019, 12:11 PM   #14
propav8r
F*ck Edgar
propav8r's Avatar
That's cooler anyway.
