Old 07-13-2019, 09:26 AM   #1
Trevor57
Trevor57's Avatar
Default Power steering fluid spraying out of reservoir.
Our Lemons car is a +t 245, and has been without power steering for many years. Recently we added back the power steering with an ac delete bracket. I was reminded of one of the reasons we eliminated the PS in the first place, since there was fluid in the engine bay, appearing to be coming from the res.
I think I may try to find an ud pulley, but I am assuming that an under drive pulley will need to be fabricated, or sourced custom. However, if anybody has one please let me know. If anyone has any ideas please let me know.
14 Mazda 5 6spd / 86 245 24hol racer / 92 245 / 86 245 lsx ( http://forums.turbobricks.com/showthread.php?t=321150 )
Trevor57 is offline   Reply With Quote
Old 07-13-2019, 11:40 AM   #2
Harry Tuttle
Is it a Saginaw pump? In my experience that is a common mode of failure for those. I don't understand it, but I finally figured out what those foam rings that sit around the cap are for. They contain the expelled fluid to running down the reservoir rather than spraying.
Originally Posted by dl242gt
It's always better to get into a turbo volvo and drive.
Old 07-15-2019, 06:33 PM   #3
Have you installed a power steering cooler yet? Those are critical imo
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
blkaplan is online now   Reply With Quote
Old 07-15-2019, 08:22 PM   #4
quillc
yv1a.com
quillc's Avatar
Yeah, your fluid is boiling over. Its a hydraulic system and the excessive (for the design load anyway) steering input is causing the fluid to expand and puke out of the top cap.
Buy a stacked plate type cooler (not fin-tube) and put a thermostatically controlled fan on it. That should solve your problem.
Chris
www.yv1a.com
Old 07-15-2019, 11:37 PM   #5
philski o'flood
philski o'flood's Avatar
whoa that's it
philski o'flood is offline   Reply With Quote
Old 07-16-2019, 03:31 AM   #6
JW240
All idiot, no savant
JW240's Avatar
+1 - my 240 usually never spills PS fluid but the few times I took it to the track it spewed lots of oil out of the reservoir. It gets really hott.
240 | 1991 | 338K Km | B230F+T | Cosworth T3 60/63 | M90 | TrueTrack
Old 07-17-2019, 09:29 AM   #7
towerymt
the real Towery
towerymt's Avatar
I had issues with my autocross car until I switched to a synthetic fluid (redline).
I would strongly suggest a cooler for a lemons car that will see hours of continuous use in the hot months. And use synthetic fluid, too.
We ran a billet aluminum underdrive pulley on our B230 in lemons. But no power steering on our car.
Old 07-17-2019, 09:31 AM   #8
Stiggy Pop
Stiggy Pop's Avatar
I have this issue as well, it really started once I started turning ~7k rpm. An underdrive crank pulley helped a fair amount, I now get weeping instead of spraying. I had not considered a cooler, but I am now!
'79 242
943 pickup
Old 07-17-2019, 10:24 AM   #9
Broke4speed
Broke4speed's Avatar
I 'improved' the cap venting with a small drillbit and my overspraying issue went away . I may add a cooler though, just in case.
Old 07-17-2019, 01:34 PM   #10
Cwazywazy
Single jingle
Cwazywazy's Avatar
I had this problem too.. I'll bring my temp gun to the track tomorrow, see how hot the lines are getting.
I don't know what I have
