Old 07-17-2019, 05:12 PM   #1
Myrsy
Default 1988 740 leaves in the ac
I bought a 1988 740 a couple of weeks ago and as i turned the ac on for the first time it started spewing leaves. I had not realized that the ac intake spot was full on leaves and some got in to the system.
How do I get the leaves out? Do i just put the ac on full blast and pray?(also the ac has never had a compressor if that is a factor)
Thanks in advance!
Newbie bonus question: what exact engine does the car have? The car is non-turbo, uses gasoline with injection system and the engine size is 2 liters.
Myrsy is offline   Reply With Quote
Old 07-17-2019, 07:11 PM   #2
TestPoint
TestPoint's Avatar
Someone with a 700 series will come along and help but on a 240 the cowl vent needs to be cleaned both up top and on both sides below the doors. Remove the carpet and find an 1 1/2" plastic plug that can be removed and vacuumed. Once the trash gets behind the HVAC box blowing it out through the vents is about all you can do short of removing the box.
Ford V8 Conversion Manual -
TestPoint is online now   Reply With Quote
Old 07-18-2019, 04:58 AM   #3
hessam69
1. Remove windscreen wipers
2. Lift bonnet
3. Remove three 10mm bolts on the firewall that fix the cowl panel to the body
4. Remove cowl panel
5. Vacuum all leaves that are visible, including inside the heater fan
6. Check leaf guard under cowl panel, re-attach if adhesive has failed
7. Buy butyl tape from Volvo pn 1161782 and fix leaf guard to cowl panel
8. Lubricate windscreen wiper linkages
9. Enjoy no more leaves and a quiet heater fan
Old 07-18-2019, 06:51 AM   #4
Fa182
Stage 1
Fa182's Avatar
Your car should have the B200F engine.
Here are some good maintenance and service tips when you just got your first 740 (it certainly helped me a lot when I got my first RWD Volvo and continues to do so): https://www.volvoclub.org.uk/faq/FAQSummary1.html
Old 07-18-2019, 08:12 AM   #5
summer_sky
summer_sky's Avatar
Thanks for posting this link!
"humility advances Life's ambitions" - Unknown
"There is no reward for settling for something you do not want." - John Mellencamp
summer_sky is offline   Reply With Quote
Old 07-18-2019, 09:17 AM   #6
Fa182
Stage 1
Fa182's Avatar
Yeah, it's just super helpful. Even the question from OP is answered somewhat there:
https://www.volvoclub.org.uk/faq/Ele...perMotorAccess
Old 07-18-2019, 12:27 PM   #7
Myrsy
Thanks for the replies everyone, they are really helpful! I will get to work on the ac when I get back home.
Old 07-22-2019, 10:28 PM   #8
Kjets On a Plane
Kjets On a Plane's Avatar
Clean leaves, install snow cap?
How PSI a stock can support?
Always Be Crushing!
