Ansel+
ABG
- Aug 3, 2009
- Portland, Oregon
Trying to replace my water pump for the first time and I ran into this. What would be the easiest way to remove this nut? I've soaked it in wd40 and tried using a breaker bar to stop the pump from turning and channel locks to remove the nut. No luck. Am I going to have to go rent a sawzall or is there another trick I can try? I can get a 10mm on it but it just strips the outside even more.
