Afternoon t-bricks, hope this nonsense finds you well.
I've had the stock T3 from my '85 760 off the car to do the exhaust manifold gaskets, install a flexible drain line to a shiny new Yoshifab block fitting, and some other sundry items on the exhaust side of the engine. I got everything back together, fired it up and it was leaking oil like crazy from the bottom of the turbo. I took it all back off and inspected. The hydraulic -AN line I had made up for the drain had a distorted mating surface inside, which wasn't helping so I installed the following-
ATP T3 drain flange to -10AN fitting adapter, installed with provided studs, gasket, and copper nuts
Unfortunately I realized too late that the studs have a long side and a short side. The short side of the studs is supposed to thread into the turbo. I instead installed the long side of the stud into the center section. I was finally able to get them both removed and new studs installed in the correct orientation, but that leaves me with three questions as I get it ready to go back on the car:
1. Is there anything in the center section that would be damaged by me installing studs that were 3/4 inch longer than intended? Oil passages that I may have damaged, etc? I looked at a diagram of an oil-cooled T3 but I can't really tell.
2. How do you clean out a turbo that has been off the car for a month or two? The oil feed/drain holes have been blocked for that time, but I've done a lot of cleaning of the turbo/manifold assembly including grinding off a stuck wastegate actuator bolt, and I want to make sure I'm not going to kill my turbo because I was too lazy to flush it before re-installing.
3. The stock oil feed hard line is still on the car. The T3 doesn't seem to want to fit in the car unless the hard line is bent slightly, then bent back and bolted to the turbo. I don't like this very much. Is this a place I need to be concerned about fatigue either in the line or with the copper washers that seal the banjo to the block?
I am probably overthinking all of this, but I figured it wouldn't hurt to get input from folks who know more than I do.
