IceCold4x4
- Feb 19, 2006
- Birmingham, Alabama
WTF is that?
WTF is that?
Clutchflyte. 'Member my stupid "manumatic" idea?
Edit: You can't get this stuff anymore. It was a fad, I guess.
they seem to be increasingly rare in volvos at the JY.
Upgraded clutches and steels. Red eagle friction packs run ~$25 and $21 for forward, and low/reverse. (forward likely needs 2 sets), the kolene treated steels are about ~$10 less a pack.
anybody try a bw55 bellhousing on a aw30-43 yet?
The only time I did anything like this was with a ZF. I used a Volvo tranny in a BMW. I swapped the bell, tail, main shaft and valve body (basically built one out of two). The only AWs' I have are from Volvos so I can't compare. I don't see a problem but you'd need them all side by side. No one will go out on a limb and tell you that it can be done. We'll have to see for ourselves.
So Kenny: When are you going to the boneyard? This weekend? I'm curious what unit you end up with. There are a number of different tail shaft lengths / housing configurations. I'm also curious if you are going to go ahead and experiment with rebuilding using a '71 tail shaft / planetary gear assembly.
Good luck!
IF the bellhousing from the bw55 will bolt up to the 7m auto, we might be in business.
fitment might not be the only issue at hand, there's also install depth, etc. even if it drops right on we might not be out of the woods.i hope to god it does but if not it would be damn sure easy to modify so it will fit.
on a side note we are talking about a bw55 housing to aw30-43 guys, why are people talking about removing the 70/71 housing still?
