Old 11-07-2019, 09:07 PM   #26
2turbotoys
Have you seen me?
2turbotoys's Avatar
Here is some more good info on this subject, I was curious which way they break and got some great replies.
https://forums.turbobricks.com/showthread.php?t=346633
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 11-08-2019, 10:46 AM   #27
stick70
All the gauges
stick70's Avatar
My setup. It's so so so so good.
I need to get on this control arm game. I'm stuck at -1.7 and 3.9.
Old 11-08-2019, 11:09 AM   #28
kyote
Living The Dream
kyote's Avatar
The KL arms and BNE Select strut mounts set to max caster make a 240 handle very very well (1.5deg neg camber and 7deg caster) . They really need delrin bushings front and rear to make them work well under heavy braking.
As far as boxing control arms...
For a DD: no real need unless your running big rubber up front, doing the occasional track day and really using your brakes. I have yet to fold/bend one at track days or drifting.
If your smashing rough roads: definitely box them.
KL Arms: I bent a set at a drift event. They’re now fully boxed, and now it destroys the rear control arm bushings if I hook a wheel on the inside curbing.
On Shane's lifty boi it brought it from positive camber to roughly zero, maybe a little negative. (KL Racing Arms and BNE select mounting plates)
Still needs a non-tape measure alignment to verify
kyote is online now   Reply With Quote
Old 11-08-2019, 11:16 AM   #29
IansPlatinum
IansPlatinum's Avatar
pics of lifty boi?
'96 854 Platinum - "Trusty"
'92 245 - "Boat"
'71 145 - "Rusty"
Previous:
'73 1800es - "Sunny"
'92 940T
'98 S70 T5
'99 S70 GLT
Old 11-08-2019, 11:53 AM   #30
ill be able to offer control arms again soon as well. Cant wait for my new purchase to show up
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 11-08-2019, 12:36 PM   #31
kyote
Living The Dream
kyote's Avatar
pics of lifty boi?
Google "Lifted Volvo 240", its the first result
Old 11-08-2019, 08:59 PM   #32
GreatDaneShane
GreatDaneShane's Avatar
https://imgur.com/gallery/u4ROSam
Here's some pictures of the lifty boi/tallvo/cucaracha
GreatDaneShane is offline   Reply With Quote
Old 11-11-2019, 03:22 PM   #33
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
I saw Ryan’s 240 back in the day crack and break a control arm while backing into a parking spot at burger ball. Could be bad luck but seems like an easy upgrade to make.
Old 11-13-2019, 12:24 PM   #34
towerymt
the real Towery
towerymt's Avatar
Volvo version, probably still gives the unibody a chance.
24hr Lemons version...we ran spacers to move the ball joint out about an inch to give -3'ish degrees of camber while still using the stock upper strut mounts. Found this ripped apart before a race. These were box'd using Yoshifab plates, but it doesn't really extend to the end, and the plate was clearanced (poorly) for the bolts holding the ball joint to the spacer.
Probably should have welded a piece across the underside of the arm, out near the end.
Old 11-13-2019, 01:01 PM   #35
pat244ti
pat244ti's Avatar
Both my race cars have them - the road race car uses the Yoshifab stuff while my rally car has Alfalfa rallysport specials [a bit beefier than Yoshifab]
Both have been doing the job just fine for their respective applications.
- Patrick
83 244ti - road race
83 244ti - rally
73 1800es - resto
08 c30 T5 6spd - daily
97 dakota 5.2 4x4 single cab short bed - apocalypse mobile
pat244ti is offline   Reply With Quote
