Old 01-03-2019, 12:02 PM   #1
ktm450
Default Tires for my 1993 940 T, can't find a tire that works in the rain
Hello,
I hate to start another tire thread but, I have had 4 sets of tires on this car and everyone has been TERRIBLE in the rain. I mean white knickle driving everytime it rains. I know that in wet or snow conditions, it is all about the tires. The last tire I put on it (mistake! DO NOT BUY THESE TIRES) are the Toyo Celcius. I bought them, knowing that these are rated as a winter tire but, shouldn't they be good on wet roads too? WRONG! Uphill right hand turns from a stop, spins the right rear like a pickup truck with baogna skin tires on it, when they were new! Hydroplane on really wet roads etc. Is this car especially difficult to get tires to stick?
After drivng the sure footed (not as sure footed with bigger sways) 240's, for 40 years, I am stumped as to why this car (longer wheelbase?) is so damn hard to find tires that work?
I am going to costco to get Michelin Defenders this month. I have heard and read nothing but good things about these tires. I am hoping that they will work on this car. Any input, or suggestions before I pop for another 500.00 for tires would be apprecited. Thanks!
KTM450
1993 940 8 valve turbo 70000 miles
1991, NA 244DL 111000.
ktm450 is offline   Reply With Quote
Old 01-03-2019, 12:58 PM   #2
Toyos suck.
<--- A +1 vote for Defenders on a DD, I got a couple new ones for $75 ea and mounted them myself at a friend's shop ftw.
Old 01-03-2019, 12:59 PM   #3
80/20 speed parts club
Since you are in Ohio, it would pay to spend the bit of extra dough up front and get winter and summer tires. All seasons are a false economy when it's icy and snowy for a significant portion of the year.
Michelin X Ice 3 or Bridgestone WS80 for when it's snowy and icy, Continental ExtremecontactSport for when water turns liquid again.
Old 01-03-2019, 03:42 PM   #4
A tough rowing ho
I like the bf Goodrich G-force sport comp-2 a/s and have recently purchased general g-max tires which are also outstanding in the rain. My only complaint with the general is the tread pattern tends to tram line on grooved pavement where the Goodrich didn't.
Old 01-03-2019, 03:59 PM   #5
towerymt
the real Towery
towerymt's Avatar
I used the previous version of these and they were very good in heavy rain, as well as on wet roads as far as lateral grip and launch / take-off-from-a-stop. so when that set wore out, I bought the new version to replace them. I like that I don't have to adjust my driving just because it's wet outside.
https://www.tirerack.com/tires/tires...eContact+Sport
I drove on a coating of snow a few times with these at half tread or better and the car did move, so I wasn't totally stranded. But I use snow tires when it actually snows, and so should you.
I had previously had some ~10yr old 205/55/16 all seasons that couldn't hook up from a stop at all, and rolling on the throttle in 2nd gear would spin so easily, it was frustrating. If you're trying hard tires (wear rating over ~500), they might just be hard tires that won't grip well when it's slick out.
Old 01-03-2019, 07:56 PM   #6
Marvelous3
Who engineered this?
Marvelous3's Avatar
16's
Michelin pilot as 3's have been the best all seasons I've used.
Old 01-03-2019, 08:35 PM   #7
ktm450
Thanks for the responses. Redwood, Yes toyos suck big! They are only a year old, and they are coming off.
A little more info. I am in the extreme south of Ohio. Our winters are lame. Every once in a while, we will get some snow. So, if we ever get any snow, I will be parking the 940 T and driving my 245 wagon with general altimax arctic tires on all 4's. So, I am more concerned with wet than snow for this car.
Also, this car isn't ever driven hard. Mostly a grocery getter.
KTM450
Old 01-03-2019, 09:01 PM   #8
Ok, get the extremecontactsports and never look back
Old 01-03-2019, 09:52 PM   #9
MrD
Originally Posted by Marvelous3 View Post
16's
Pilot sport A/s 3+ Are the next gen and have better snow traction.
1993 940 Turbo - Silver / Grey
MrD is offline   Reply With Quote
Old 01-03-2019, 10:33 PM   #10
I had the pevious gen and am rocking the as3+ in the Acura. Still not great in the snow. Fantastic otherwise. Would still rather use a ps4s instead.
Old 01-03-2019, 10:44 PM   #11
MrD
Yep i had both on the soobie, the 3’s were terrible, the 3+ are better than the 3s.
Old 01-03-2019, 11:50 PM   #12
woodenpudden
lacks goats
woodenpudden's Avatar
I've run the aforementioned Continentals, General G-max, and BFgoodrich for years, all really good in the rain. Goodyear Eagle F1 asymmetric are also really good/predictable in the rain, have had them on two cars now.
Originally Posted by DMFWallace View Post
Flunt delivers!
woodenpudden is offline   Reply With Quote
Old 01-04-2019, 12:24 AM   #13
c1800
Check out tirerack, they have a rating system based on thousands of owner reports. Shows several categories such as comfort(noise and ride) and wet and dry traction, and others.
Good luck.
An example
https://www.tirerack.com/tires/surve...jsp?type=UHPAS
Old 01-04-2019, 05:34 AM   #14
Otto Mattik
Otto Mattik's Avatar
I agree, I've had good luck with Nokian's dedicated winter tires(look for mountain logo) & don't fool around with "all season" (waste of time) any more
Originally posted by Jack
_________________________
Feedback Link: forums.turbobricks.com/showthread.php?t=323689
Old 01-04-2019, 06:06 AM   #15
Fa182
Stage 1
Fa182's Avatar
+1 for Continental
Since I started to use only Continental for summer (Premium Contact) and winter (Wintercontact TS860), I noticed what huge difference tires can actually make in the wet and snow (we get very slippery roads here sometimes in winter due to the salty slush). They are superior to everything else I've tried and they continuously rank on the podium in the tests of our local AAA and its German counterpart.
Worth to spend the extra bucks, but I'm not sure if you get these models in the US as well.
Fa182 is online now   Reply With Quote
Old 01-04-2019, 08:09 AM   #16
Marvelous3
Marvelous3's Avatar
I don't think you can get the ps4s in 16". I would have much rather put Super Sports on my grey car but they're not available in 16's which is how I ended up in the AS3+.
Continentals ride like truck tires to me and I've always had good luck with Michelins. I'm sure any of the major brands top tier tires will be good tires. I'm always a little confused by people who will skimp 20-30 dollars per tire on something they're going to have for the next 40-60k miles and hours of their life. Like what's an extra $150 for something that you're going to have for the next 3-5 years and will NEED when things get weird outside. /rantoff
Old 01-04-2019, 01:56 PM   #17
Coming from Cheapskate Extraordinaire, that's saying something
I had the opposite experience with Contis. All of the ones I have sampled tended to ride a bit better than Michelins. The Extremecontactsport is available in 16" sizes and is nearly as good as the PS4S.
My take is that these summer tires are better than winter tires at almost any temperature in the dry and wet. All seasons and winters are only good if there is freezing water forming on the road surface. You only need all seasons if you drive enough to wear out your tires in less than 5 years and have no room to store a spare set. Otherwise, separate summer and winter tires is the way to go.
Old 01-04-2019, 02:56 PM   #18
300+hp on the shelf club
I change tires seasonally and this past couple sets of winter tires I cheaped out and bought discount tires that were nos. The last set were three year old stock Falken Euro winter in 205-60-15. A good size for pot holes and bad roads of the winter. They were $250 for a set of four and they have been great in the rain and very good in the snow.
This is the cold rain of the winter. So a winter tire with it's softer compound will respond and handle very well. Also I didn't see mention of tire pressure. What do you run your tires at? If you use 40psi in your tires for example because you want maximum mileage. Your car is going to suck in the rain no matter what type of tire.
I run my winter tires at 33-34psi most of the time. But if I need traction I will lower it to 30. I don't like to run them lower than that. These are on the 93 wagon.
Old 01-04-2019, 03:06 PM   #19
SquareD
An Anomaly
SquareD's Avatar
Contis tend to have softer sidewalls and ride better. Michelins theoretically last longer but are usually considerably more expensive. I'd probably recommend some Conti's myself. I've had a few sets and always been happy with them.
Old 01-05-2019, 02:24 PM   #20
JohnLane
I use Contis on the MB for all seasons. Almost as good as Michelin Pilot Sport in the summer, excellent in the rain and not scary in ice/snow. They last wayyy better then the pencil eraser Michelins and are quiet for 75% of their life.
Old 01-13-2019, 10:59 AM   #21
dalek
Benchracer Tribe
dalek's Avatar
I use dracos in my car, so I am stuck to 15" for the time being, and having been buying 185/65 R15 tires. Is there a better (more options) size for that rim?
Feedback!
Old 01-13-2019, 11:48 AM   #22
freevolvos
freevolvos's Avatar
Hard to beat the winterforce in snow and rain for the price, you'll get about 2-3 years out of them running year around, they are a bit noisy tho
Old 01-13-2019, 04:27 PM   #23
dirtbag240
for my winter and rain tires, i have nokin Hakkapeliitta 9's studded and Nokian wrg3s for the rainy season and so far they have been absolutely fantastic, super controllable when the grip does run out and amazingly drivable in the snow both of them
dirtbag240 is offline   Reply With Quote
Old 01-14-2019, 01:55 PM   #24
Summer tires are better in rain, every time.
Old 01-14-2019, 03:38 PM   #25
gsellstr
Vintage anti-ricer
gsellstr's Avatar
Good info on the new Conti's...debated those before my current set of Potenza's, probably will go Conti again next set.
For the OP, I've run the Conti DWS and the newer DWS06 on the wife's car with very solid results. Heavy rain, standing water, really no issues. The DWS were on her 850R, ran 2 sets. Had them on coming thru the mountains, hit some ice and they held surprisingly well, but that car also had TRACS to help. Never had an issue with hydroplaning as long as I was driving relatively sane. Her current car (V50T5 AWD) has the DWS06's on it. I've been thru some random standing water at 70mph and aside from the noise they just stuck. Can't really spin a tire on the car anyway, but tire grip has been great. Handling on the DWS06 is MUCH better than the previous DWS, meaning I can actually push the car a bit during the summer as well. It's still stock suspension-wise, also a grocery getter.
My findings with Conti have also found they have softer sidewalls than Falken and Bridgestone, so a much nicer ride. The only downfall is the corners aren't built up as much so they tend to wear the shoulders more than I'd like. They are also a good bit cheaper than some other options, also lighter.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
