Old 01-06-2019, 10:24 PM   #1
golddayton101
Default OEM 240 Oil Temp sensor
I ordered a new oil temp sensor for my 240 and was wondering where it hooks up to? The PO put a normal drain plug when his sensor stopped working.
golddayton101 is offline   Reply With Quote
Old 01-06-2019, 10:41 PM   #2
The sensor replaces the drain plug.
There should be a black wire that connects to the sensor that runs to the back of the gauge.
http://www.240.se/litteratur/3-38-13a.pdf
Where did you find the OEM sensor?
Old 01-07-2019, 01:00 AM   #3
Mr. V
Mr. V's Avatar
Between the oil filter and the water pump on the passenger side of the the red block.
Old 01-07-2019, 02:45 AM   #4
MasterBlaster
......is where we find the oil pressure switch, yes?
470,000 km so far...
Old 01-07-2019, 10:09 AM   #5
golddayton101
I’ll check behind the gauge and see if the wire is tucked behind.
Old 01-07-2019, 12:43 PM   #6
Mr. V
Mr. V's Avatar
Oops, yeah: my redblocks don't have an oil temp sensor, only an oil pressure sensor: my bad.
Old 01-08-2019, 02:47 PM   #7
golddayton101
Local Volvo shop had one NOS.
Old 01-08-2019, 03:03 PM   #8
How much did it cost? This guy was asking over $275 for a NOS sender.
https://www.ebay.com/itm/Volvo-240-2...frcectupt=true
Old 01-08-2019, 09:19 PM   #9
Mr. V
Mr. V's Avatar
The pic of the sensor looks like it is too narrow to thread into the bottom of the oil pan, to take the place of the oil drain plug.
The pic looks a look like a water temp sensor.
Hmmm.
Old 01-10-2019, 12:40 AM   #10
neptune
Is 19 cars too many?
neptune's Avatar
Nice score.
Wire routing varied since these were all dealer/shop/owner installed. May have to crawl under there and search for an unplugged single spade connector that doesn't look like it belongs. Or trace it from the gauge. I think I ran mine down the firewall and then over to the oil pan via some zip-ties on the lower tie bar. Probably should have gone down the intake support bracket instead.
The picture looks exactly like the one I have in the oil pan of my car. The flats are slightly smaller than the original drain plug (25mm). I can't remember for sure but I think the oil temp plug is 19mm. And it is a big heavy unit. Still working fine a decade later.
www.neptune242.com
1981 242 Turbo |1996 850R |1980 Coupé (Project)
neptune is offline   Reply With Quote
Old 01-10-2019, 01:37 PM   #11
lummert
lummert's Avatar
Originally Posted by neptune View Post
Nice score.
The oil drain plug should be 3/4-16.
Old 01-10-2019, 03:45 PM   #12
300+hp on the shelf club
The oil drain plug temp sensor has the same 3/4 16 thread but the hex flats are only 22mm instead of 25 aka 1" like the stock plug.
Old 01-14-2019, 01:42 PM   #13
golddayton101
I’ll look behind the gauge and see if the wire was left there.
