Old 04-19-2016, 09:26 PM   #1
chris gilmour
Default removing rear side windows?
I have a 1990 245
it has a strange rust spot on the inside of the rear drivers side window. The one in the trunk area. I was curious what the procedure is to remove this window with out using a rock?
chris gilmour is offline   Reply With Quote
Old 04-19-2016, 10:21 PM   #2
A window installers draw knife is the correct tool, but I use a paring knife.
AUTOMOTIVE WINDSHIELD GLASS WINDOW REMOVER HAND TOOL CUT GLUE SEAL GASKET
http://forums.turbobricks.com/showthread.php?t=298421
Old 04-19-2016, 10:37 PM   #3
chris gilmour
does this require cutting the seal? and replacing with a new seal?
Old 04-19-2016, 10:44 PM   #4
Tuff240
240 Ninja
Tuff240's Avatar
You can just lift the inner lip up and push it over the metal lip and slowly work your way around until the window is loose enough to pull out. I've used a couple flat screwdrivers more times than I can count.
-Patrick
Old 04-19-2016, 10:47 PM   #5
Yes it's set in butyl flex.
3M™ 08610 Windo-Weld™ Round Ribbon Sealer, 1/4 inch, 8610
Old 04-19-2016, 10:55 PM   #6
Tuff240
240 Ninja
Tuff240's Avatar
Ken, pull your head out. He's talking about the 245 rear quarter window. It's just a rubber seal lipped over a metal lip on the body.
Like the rear was up to 1989:
Old 04-19-2016, 10:59 PM   #7
Ok that's covered on page 2 of my build thread.
Flip the seal back and push it out with your feet.
82 245 GLT Paint 9
Old 04-19-2016, 11:20 PM   #8
chris gilmour
awesome! ahah thanks!
Old 04-20-2016, 02:20 PM   #9
bobxyz
bobxyz's Avatar
What are the options for replacing or rejuvenating or re-sealing the rear quarter window rubber so that water doesn't leak around the glass channel?
Would a windshield shop be able to source a similar profile in new rubber?
'85 245glt aw71 k-jet -> lh2.4
Old 04-20-2016, 02:31 PM   #10
90 + seals.
Old 10-14-2018, 09:46 AM   #11
colinjbriggs
90 + seals.
How do I get myself some of these new rubber seals for my 1985 240 estate? I'm going round in circles on the internet...
colinjbriggs is offline   Reply With Quote
Old 10-14-2018, 10:15 AM   #12
white855T
I think this might help. https://www.volvopartswebstore.com/s...roduct=1118884
Buyer/Seller Feedback
Old 01-13-2019, 12:24 AM   #13
isaac.j.freeman
isaac.j.freeman's Avatar
Thank you for this post. It is what I was looking for over the past week! My rear side window gaskets are shot and I need to replace them. Not an easy thing for me to find.
isaac.j.freeman is offline   Reply With Quote
Old 01-13-2019, 12:28 PM   #14
nel621
Tough crowd , RWC.
Old 01-13-2019, 12:33 PM   #15
Originally Posted by nel621 View Post
Tough crowd , RWC.
Right?
I used to pull those seals before $14.99 was dizzyingly expensive.
