Old 12-26-2018, 08:18 AM   #1
Chumley360
Default Ambient temp gauge light
I figured I'd ask before climbing into the dash. Is the backlight for the ambient temp gauge on a 1995 944t non-serviceable? Since it appears to be some type of crystal display that the light is integrated into the unit and has to be replaced as a unit. I figure I'll check for power coming from the light switch too. But if it's only serviceable as a unit checking this is going to the bottom of the list of things to work on.
Got boost? Yes! Got manual? Yes! Got gear? Yes! Got V-8 power? No
1995 940t
Chumley360 is offline   Reply With Quote
Old 12-26-2018, 11:38 AM   #2
Fa182
Stage 1
Fa182's Avatar
You can change the bulb in it. Take out the cluster and you can access it.
Here's a photo when I replaced the unit with a boost gauge.
File Type: jpg 26972545_10215617894424412_9151313_o.jpg (198.1 KB, 67 views)
Old 12-26-2018, 11:53 AM   #3
Chumley360
Sweet, thanks!
Old 01-12-2019, 04:45 PM   #4
Chumley360
OK so I pulled that out today and found that this bulb is a bulb/socket unit. I hunted around and found one in my stash to replace it. Now my question is, is there a way to fit a a two piece light(like the idiot lights in the dash)? If not does anyone have a source for these? I checked FCP, IPD and a few others, but had no luck.
Old Yesterday, 07:52 AM   #5
Chumley360
I was looking through IPD this morning for some 240 stuff and found bulb #100929(https://www.ipdusa.com/products/4824...ash-light-bulb) and that looks like the bulb unit I'm looking for, can anyone confirm this?
Old Yesterday, 01:53 PM   #6
philski o'flood
philski o'flood's Avatar
^yes that's it. 240 cluster and also 850 cluster.
philski o'flood is offline   Reply With Quote
Old Today, 10:26 AM   #7
Chumley360
Sweet Thanks!
