Old 12-29-2018, 06:36 PM   #1
alex1366
Default Rear Window Demister
I have an old 1989 Volvo 240 DL. The rear demister is not working at this time. When I push the button, the fuse just blows immediately. I pulled the switch (I am not an electrician) and just did a continuity test, and it seems to indicate that it is working properly when I push the button in. There are no visible scratches on the wiring in the rear window. Could anyone help me with this issue. Thanks very much!
alex1366 is offline   Reply With Quote
Old 12-29-2018, 06:46 PM   #2
smeha
Tranny Whisperer
smeha's Avatar
I disconnected mine on the fuse since it's a fire hazard and mine is a wagon with every 10 years broken wires in the hatch. Sedan or wagon?
1997 Jeep Cherokee Sport (XJ) (Engine: 4.0L - I6) (2WD)
My Feedback Thread
<--- Just a dumpster on fire
Old 12-29-2018, 10:06 PM   #3
cleanflametrap
cleanflametrap's Avatar
Assuming your 240DL is a 245, you might need to repair or replace the wiring harness(es) passing through your tailgate hinges. If not, and it is a sedan, then you've got some sleuthing to do.
-Art
Old 01-05-2019, 05:55 PM   #4
alex1366
This car is a sedan.
Old 01-15-2019, 07:22 PM   #5
alex1366
Default 1989 volvo 240 DL rear window demister not working
Hi!
My rear demister is still not working. I have tried the following:
Cleaned all contacts at fuse box (fuse 11), switch and grid.
Pulled, cleaned and checked panel switch
Made certain the problem is not related to the overdrive wiring
Replaced the relay
Fuse blows even when the relay is removed
Completely disconnected overdrive button wiring
Checked continuity at grid
The fuse does not blow when the panel switch is disconnected
I would be very grateful for any advise!
Thanks, Alex
