Old 01-05-2019, 02:26 PM   #1
Marvelous3
Who engineered this?
Marvelous3's Avatar
Default brake light out dash light/ no brake lights
90 240. With my lights on I get a bulb out warning dash light. Turn lights off and the dash light goes away. In both cases my brake lights don't come on. I replaced the bulb out relay, the big red one, but that has not fixed the problem. Is there a brake light switch that the pedal makes contact with?
Old 01-05-2019, 02:36 PM   #2
It's up under the dash.
https://www.tascaparts.com/oem-parts...switch-3544691
Old 01-05-2019, 02:38 PM   #3
2manyturbos
Yes. It isn't too hard to change. The pins face toward the driver seat making it fairly easy to test the switch with an ohmmeter.
Old 01-05-2019, 03:28 PM   #4
Marvelous3
Marvelous3's Avatar
I mean I have no brake lights right now. Between the relay and the switch that should complete the circuit right?
Old 01-05-2019, 03:36 PM   #5
Yep. Grab a test light, cram your head under the dash and make sure the switch has power to one pole. Press the pedal and both poles should have power.
Old 01-12-2019, 02:03 PM   #6
Marvelous3
Marvelous3's Avatar
Replaced the relay but still nothing. I circled back to the fuse panel and noticed that the fuse was blown again. Looks like one of the tail light boards is a little funky and was blowing the fuse on contact. Stupid ass 240 sedan tail lights...
Anyways, the old relay was kind of crusty so I'm sure it was headed out sooner rather than later.
