Old 01-05-2019, 03:41 PM   #1
RickATL
RickATL's Avatar
Default stupidly sandblasted ATE caliper
I was cleaning up a set of rear calipers from a 1993 240.
I was sandblasting and stupidly "lightly cleaned" the receiving cup for the piston.
Any opinion on whether they are runied?
RickATL is offline   Reply With Quote
Old 01-05-2019, 08:34 PM   #2
Dirty Rick
Dirty Rick's Avatar
Not ruined, the piston has the finish that is critical.
Be sure to get the seal groove clean.
Old 01-06-2019, 09:19 AM   #3
Happy Mew Year!!!
Maybe run a small hone through it? I'm no expert so use my advice at your own risk
Old 01-06-2019, 11:36 PM   #4
quillc
yv1a.com
quillc's Avatar
Just get a brake hone and hone it.
Its what the rebuilders do anyway.
Chris
www.yv1a.com
Old 01-07-2019, 12:42 AM   #5
Dirty Rick
Dirty Rick's Avatar
You don't hone brake calipers!
To rebuild you media blast the caliper and replace the piston.
Old 01-07-2019, 07:55 AM   #6
hikerguy
hikerguy's Avatar
So long as they're not too pitted I'd run them. My 960 rear brakes were seized from rust, with very light pitting on the bottom. It's been at least 10k since then and no visible issues. The hardest part is getting those dust boots on. I installed the Piston seal, then the boot with a collar to hold it wider then the Piston then just drop the Piston in. I think the collar I used was the outer ring of a spray paint lid. Good greased slides should keep the Piston from dragging the bore for the most part anyway.
+1/2 million miles of white block sitting in the drive way
hikerguy is offline   Reply With Quote
Old 01-07-2019, 11:44 PM   #7
RickATL
RickATL's Avatar
Thanks. After some more research, i found out about the brake hone, got one, and they seem perfectly smooth again.
Old Today, 01:14 PM   #8
mikep
The MP
mikep's Avatar
Actually, you do, if they are corroded. glass beads embed in the surface, and will wear out the seals. Honing and cleaning will fix that. (honing without cleaning is juju)
If the pistons are pitted or flaking you replace them. If not, wire wheel and re-use.
And do NOT use vaseline like these knuckleheads suggest. ANY petroleum product on brake seals, boots, etc. is also bad juju.
Everything about ancient rome was beautiful, so no 740s would exist.
