Old 01-05-2019, 04:24 PM   #1
GeneralBurrito
GeneralBurrito's Avatar
Default Are injectors on the 240 just naturally loud?
Both before and after doing my b cam swap (only barely needed to adjust a couple valves), replacing the entire exhaust from the manifold back, and changing to 850 yellow injectors, I still have a tick when I accelerate. I think it might be injectors since it goes silent during deceleration, which could probably be fuel cut off.
Old 01-11-2019, 04:58 PM   #2
300+hp on the shelf club
Unless there is some other engine issue creating a louder noise. I can always hear that clicking sound of the injectors.
Maybe they have injectors designed to be quiet on higher end cars like a big benz or lexus?
Old 01-11-2019, 05:58 PM   #3
quillc
yv1a.com
quillc's Avatar
Personally, I don't think that its the injectors.
Given the number of miles that most of our engines have, its likely piston slap.
Chris
www.yv1a.com
Old 01-11-2019, 06:23 PM   #4
A ticking noise on acceleration can be exhaust leak at the cylinder head to exhaust manifold gaskets.
Old 01-11-2019, 11:37 PM   #5
GeneralBurrito
I thought it would be exhaust leak, but I replaced every exhaust part and gasket other than the manifold itself. There might be a chance that it could have a crack, but I've had a shop I worked in check for a leak and said nothing about the manifold.
Old 01-11-2019, 11:42 PM   #6
GeneralBurrito
Do 240s have a fuel cut off though, because it only ticks when I get on the pedal. The second I pull off the pedal, it goes away immediately. Even like a slight push and it's faint, loudest at heavy load.
Old 01-14-2019, 11:42 AM   #7
JohnLane
Pistons are noisy when loaded.
Injectors are not heard over all else happening under the hood.
Injectors in your Volvo are quiet compared with Direct Injection injectors in modern anything. Manufacturers make up fancy moulded insulation things + plastic covers to seal the noise in.
Old 01-14-2019, 01:10 PM   #8
freevolvos
freevolvos's Avatar
Maybe you need a valve adjustment
Old 01-14-2019, 01:46 PM   #9
GeneralBurrito
I'll look into possibly getting another valve adjustment when j change my oil.
Old 01-14-2019, 05:53 PM   #10
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
I have these Bosch/Ford Motorsport 39lb things in my car and they are LOUD. I don't know if that is correct, But it doesn't seem to effect much.
1980 242 Turbo
2004 V70R
Old 01-14-2019, 10:46 PM   #11
Harry Tuttle
Originally Posted by dl242gt
It's always better to get into a turbo volvo and drive.
Old 01-15-2019, 12:04 AM   #12
GeneralBurrito
Originally Posted by Harry Tuttle View Post
I also replaced the gasket between the manifold and head a couple months ago, but thanks for the input.
Old 01-15-2019, 10:18 PM   #13
Harry Tuttle
Misread that as "manifold gasket". Like others, I am still skeptical of the loud injector theory.
Old 01-16-2019, 12:34 AM   #14
GeneralBurrito
I already did a valve lash adjustment, but I'll ask my guy if I need another one or if he can check for a leak on the manifold itself.
