Old 01-10-2019, 12:37 AM   #1
jjona5
Default ohm/resistance on 87 740 fuel gauge anyone know?
Does anyone know what the ohm range on a 740 sending unit is?
I found some info https://forums.tbforums.com/showthread.php?t=283898 but there are two ranges and they are the opposite of one another. I want to buy a set of aftermarket gauges and the company I'm going to use will do a custom range if you tell them in advance. My sending unit looks terrible and I don't have another one yet so I figured it wouldnt be worth it to pull it again and run the range as it might not even be right.
jjona5 is offline   Reply With Quote
Old 01-10-2019, 01:32 PM   #2
lummert
lummert's Avatar
Later models are backwards. I'm thinking earlier is 0-280 ohms. A VDO 5 Bar oil pressure gauge is a close match to the fuel sender range.
Old 01-14-2019, 12:22 PM   #3
DEK2688
RTFM
DEK2688's Avatar
From TP-305181 '91 700/900 Specifications:
The immutable law of multiplicative idiocy:
Idiocy is multiplicative. Two half-wits do not equal a full-witted person; they equal a quarter-witted person. Stupidity does not build upon stupidity to create genius. It breeds like a bucket full of coked out hamsters.
DEK2688 is offline   Reply With Quote
