Old 01-11-2019, 01:21 AM   #1
t8fanning
8v are still cool, right?
t8fanning's Avatar
Default Available Heater Core Brands
I've pulled the heater box on my 240 to fix the recirculation door actuator and blower motor and figure I might as well replace my heater core while it's all out. I've read/heard bad things about pretty much every brand except OEM. What is my best course of action? Keep using the OEM one with an unknown remaining lifespan? Buy a ready aire from IPD? Buy one from amazon with plastic end tanks? Try to find a new OEM one? I haven't noticed any symptoms of my current core failing yet, but I don't want to pull it out again.
1982 242 Turbo.
Old 01-11-2019, 01:40 AM   #2
Bolzen
I wouldn't risk plastic in this application unless it's something like PTFE which isn't the case. Aluminum might do in principle if made with the correct flow management and probably can last as long, but it doesn't purify the air as good as copper/brass. Probably this is the reason why OEM part was made of that material.
Bolzen is offline   Reply With Quote
Old 01-11-2019, 04:53 PM   #3
Can play the blues
Have your heater core pressure tested if you are worried about it. If it passes and doesn't have any signs of corrosion damage. I would just keep using the original. They are the best and aren't reproduced.
Old 01-13-2019, 08:59 PM   #4
nel621
^ this
Old 01-13-2019, 09:48 PM   #5
RvolvoR
Ive put the brass replacement units in a good number of cars now with no issues. I have only heard/seen 1-2 failing in a short duration after install. I think those might or might not have been because of people not putting foam tape around the outside of the core to dampen vibrations to it.
Old 01-14-2019, 02:54 PM   #6
GTJordan
Been here for too long
GTJordan's Avatar
Take it to a radiator shop to have a new core put into it. I know a few locals who've done it successfully. I put in a plastic/metal unit in my 740 and it leaked within a year.
80 242- 2.5L, T5, Porsche brakes, short billies and kaplenkhe suspension, trutrack.
