Old 01-11-2019, 02:51 PM   #1
ElHefe910
ElHefe910's Avatar
Default Vida Dice help tips
I have a purpose built Dell running all the requirements. I've gotten it to install but it doesn't recognize the Dice communication tool. Just a black X in the top left corner. I see that this is a common issue. I've tried typing in "regidit" after pressing the windows and R key at the same time but windows could not find file. I was trying to follow these steps provided by http://blog.cardiagtool.co.uk/how-to...nication-tool/ Any ideas or help would be greatly appreciated. It is a clone program I bought off Ebay.
ElHefe910 is offline   Reply With Quote
Old 01-11-2019, 02:54 PM   #2
ElHefe910
ElHefe910's Avatar
I may just take it to some computer store and see if they can get it working for me
Old 01-11-2019, 03:42 PM   #3
gsellstr
gsellstr's Avatar
You need regedit, not regidit.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 01-11-2019, 10:44 PM   #4
dorvin
idunno
dorvin's Avatar
Interesting, they spelled it wrong in the article. Type 'regedit' instead, and follow the guide. Always double check that you're in the right area in the left hand column before modifying any values.
'93 Volvo 240 Classic sedan - 683/1600
'77 Oldsmobile Cutlass Supreme
dorvin is offline   Reply With Quote
Old 01-12-2019, 04:34 PM   #5
doucheNozzle
doucheNozzle's Avatar
https://forums.swedespeed.com/showth...Windows-10-Pro
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
Old 01-12-2019, 04:49 PM   #6
ElHefe910
ElHefe910's Avatar
Originally Posted by doucheNozzle View Post
Thanks for that link. I feel like I'm so close to getting it to work. Vida is installed properly I believe. Everything works except Vida doesn't recognize the Dice but the computer recognizes it and says it's running correct with no new driver updates. The Dice unit also lights up like it should once plugged into obdii. However I think my computer is running with IE11 but everything seemed to install correctly.
Old 01-12-2019, 04:50 PM   #7
doucheNozzle
Follow that guide from the beginning and it will work.
Old 01-14-2019, 04:04 AM   #8
gottarollwithit
Cooks with motor oil
Or, if you give up, for like 100 bucks you can just buy the Dice unit off Ebay that all the SS guys use. The seller is in Lithuania, but will remote connect to your computer and set it all up if needed.
1988 740 turbo wagon/squishmobile!
gottarollwithit is offline   Reply With Quote
