Old 01-12-2019, 06:55 PM   #1
tomasss
tomasss's Avatar
Default AC wiring help
Anybody has an AC wiring diagram for 1990 740 turbo (b204gt but hopefully should be the same for all turbos)? Its the manual one where you have to move the slider to change the temperature...
My wiring is messed up and I would like to put it back in the original state. And volvowiringdiagrams is still down...
Volvo 740 Turbo B204GT 1991
It's the oversteer that scares passengers. It's the understeer that scares the driver.
Originally Posted by Wren View Post
I would rather push a 240 than drive a V70.
lazy PRV engine? Check >this< out
tomasss is offline   Reply With Quote
Old 01-12-2019, 07:49 PM   #2
https://web.archive.org/web/20151223...20Diagrams.pdf
Old 01-12-2019, 08:33 PM   #3
DEK2688
RTFM
DEK2688's Avatar
1989 740 AC system, ‘90 should be similar if not identical:
The immutable law of multiplicative idiocy:
Idiocy is multiplicative. Two half-wits do not equal a full-witted person; they equal a quarter-witted person. Stupidity does not build upon stupidity to create genius. It breeds like a bucket full of coked out hamsters.
DEK2688 is offline   Reply With Quote
Old 01-26-2019, 06:29 PM   #4
tomasss
tomasss's Avatar
Ok, that doesn't help as much as I was expecting.
The thing is, probably like half of the ac in my car has been home-made, not using original parts. And I really want to get rid of all this stuff, because it's done horribly and the ac is not working anyways.
In the engine compartment, I have these plugs hanging:
Everything comes from the same wiring, with colors:
1 green green
2 brown greenwhite
3 blackwhite blackwhite
4 green (cut and soldered onto green)
5 greenred (that one comes from the wiring harness on the second pic)
6 blackwhite bluegreen
Is any of the plugs ringing a bell? If I remember correctly from my previous car, number 1 was there and also I remember that round plug #4. But the rest...no idea...
