Old 01-12-2019, 06:59 PM   #1
Matt244
Default AW70 not shifting after OD seleniod bypass install
my car is a 92 244 it was having some issues with the OD seleniod before. its only shifted into 4th after driving for a while and the trans got hot. I figured it was the OD Seleniod so I ordered an IPD byass plate installed it and now it wont shift from 1st gear at all. shifts from park/neutral/reverse into drive but wont shift from first when you go to drive. I checked fluid and it's operating range. maybe a piece of trash got in it when changing the seleniod? drop the oan change the filter? Did I Install backwards maybe?
Matt244 is offline   Reply With Quote
Old 01-12-2019, 07:04 PM   #2
lummert
lummert's Avatar
How many O-rings did you use? Make sure the trans has enough ATF.
Old 01-12-2019, 07:27 PM   #3
Matt244
both orings came off with the old one. I started it without it on there and it moving fluid. it wasnt leaking. I checked the fluid and it seemed ok it was in the cross hairs.
Old 01-12-2019, 08:07 PM   #4
Matt244
I put the seleniod back in and it shifts again. The fluid looks like it's done. its dark and really thin some maybe its not building enough pressure.
Old 01-14-2019, 07:19 PM   #5
smeha
Tranny Whisperer
smeha's Avatar
Inner o ring should not be used with bypass plate and make sure you installing right way, not in reverse.
1997 Jeep Cherokee Sport (XJ) (Engine: 4.0L - I6) (2WD)
My Feedback Thread
<--- Just a dumpster on fire
Old 01-14-2019, 08:17 PM   #6
Matt244
only used tge oring the bypass came with. had the slot towards the front of the car. the kickdown cable does seem to be hanging up. so i think that needs replaced as well ahvent had time to mess with it yet.
Old 01-14-2019, 08:26 PM   #7
lummert
lummert's Avatar
The O-ring that came with my bypass plate from IPD was too thin to seal properly, resulting in a fluid leak. A fluid leak at that location would cause not going into overdrive. I ended up using a slightly thicker O-ring.
Old 01-15-2019, 01:48 AM   #8
Matt244
it wouldnt even shift from first much less into OD with the bypass. it wasnt leaking either.
Old 01-15-2019, 09:50 AM   #9
cleanflametrap
cleanflametrap's Avatar
KD cable hung
-Art
