alschnertz
Enough already!
- Oct 4, 2009
- CT
My home remedy is 1/2 quart ATF added to the crankcase for 400 miles before the next oil change.
M1 has kept my wagon and the 850 with 300k on it as clean as what Ken posted a pic of earlier. Pretty damn impressive.
I do remember doing a cam swap years back on a 300k pennzoil motor in the BadVolvo, looked right on par with the OP's motor. Known service history of pennzoil every 3500 for the last 150k.
IMHO,perhaps the maintenance intervals were, um, extended towards the last. Low grade, and low detergent oils will often cause this condition,as well as short tips that prevent the engine coming up to full operating temperature for long enough to dislodge any deposits. The only for sure cure I know is remove, clean out and reinstall, but I'd just do the top and bottom, use diesel oil, and a lot of oil filters; you may go a long time.
pennzoil... made those waxy deposits that you see in the OP's picture.
cleanflametrap has http://cleanflametrap.com/oilpan/
very clever way to lift the engine enough without a hoist
