Old 09-02-2017, 12:09 PM   #101
BR1CKHOUS3
Issa Brick
BR1CKHOUS3's Avatar
What's McKevitt? I'd be up for a trip to Sacramento soon
We don't do it for the glory.
Originally Posted by SlowRide View Post
Only two ways to find out...18 bolts or 18psi
BR1CKHOUS3 is offline   Reply With Quote
Old 09-02-2017, 03:29 PM   #102
gsellstr
Vintage anti-ricer
gsellstr's Avatar
Got a thread on events, McKevitt Volvo, next Saturday, Oct in San Leandro. Our the following weekend there is a generic car meet up here is Sac that the Sac chapter is attending, fundraiser so it is 20 to reg.
Figure I will take the wagon next weekend, nicer on long drives, 140 the following weekend.
RIP
74 144 B20
90 745Ti
Old 11-15-2017, 02:07 AM   #103
BR1CKHOUS3
Issa Brick
BR1CKHOUS3's Avatar
Passed smog with really good numbers. Gotta do something about the one tire fire now that it runs pretty strong
Old 02-27-2018, 11:31 AM   #104
BR1CKHOUS3
Issa Brick
BR1CKHOUS3's Avatar
So....T5 injectors ARE apparently plug and play because I put a set in and the car runs Already has a 3.0 bar FPR
Engine is pretty tired and leaky. Trying to find a low-mileage bottom end before Davis
Been happy with the rebuilt 15g. Think the stock turbo was blown?
Old 04-07-2018, 07:15 PM   #105
BR1CKHOUS3
Issa Brick
BR1CKHOUS3's Avatar
More Davis prep. 1/2 off weekend at pick n pull so I'm swapping my hydraulic mounts for the old style ones and replacing a control arm that got tweaked by a pothole a while back. A little rain doesn't stop a TB'er
Old 04-10-2018, 05:27 PM   #106
BR1CKHOUS3
Issa Brick
BR1CKHOUS3's Avatar
Put the E-fan setup from my 242 in for Davis. Need to clean up and paint the radiator top and IC pipes once I R&D the fan for a couple days and test it out Excited for Davis if y'all can't tell
Old 04-16-2018, 03:42 AM   #107
Janspeed
Originally Posted by BR1CKHOUS3 View Post
is it me or is the passengerside strut topmount installed backward? (L and R topmounts are not installed in the same orientation)
The effect would be less caster angle on the passenger side resulting in less grip in tight left turns. It also has adverse effect on straightline stability.
Easy fix: just jack up the car, maybe remove s/bar droplink, remove topmount nuts, somehow pull that strut downward, spin topmount around 180degr, put nuts back on, etc. Done.
Other then that: nice car!
Old 04-16-2018, 11:05 AM   #108
BR1CKHOUS3
Issa Brick
BR1CKHOUS3's Avatar
You may indeed be right...I measured with a tram bar previously and the passenger side is indeed tweaked, but I will flip the mount around and see if the 'tweak' goes away. Definitely not above making a simple mistake like that. Thanks for the sharp eye! I'll post results in a few days...the car is going up on jack stands for a rear main seal, wheel polishing, and some suspension correction
Old 04-17-2018, 08:25 AM   #109
Janspeed
no worries, i have seen it before. I think it is a bit of a design error. Volvo should have designed that topmount so it would have 3 bolts in a triangle configuration. That way it would only be possible to install that topmount in 1 correct orientation.
Let us know if you can feel the difference.
Old 04-17-2018, 02:07 PM   #110
BR1CKHOUS3
Issa Brick
BR1CKHOUS3's Avatar
I will definitely report back with my findings
Time for rear main, distributor rebuild, motor mounts, tranny mount, other Davis prep...
Old 04-18-2018, 03:51 PM   #111
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
how is your garage so empty??? Godspeed on your endeavors.
1980 242 Turbo
Old 04-18-2018, 04:30 PM   #112
SquareD
An Anomaly
SquareD's Avatar
Yeah man, looks like a nice space to work. Get er dun.
1994 945ti | 15g @ 14psi, Turbosmart EBC, AEM Failsafe WB, 3"/2.5" exhaust, d088 intercooler, iPd cam, STS cam gear, Ostrich LH tune, sbabbs EZK chip, green giants, K&N, Yoshifab CCV/Can/Cap, iPd SS brake lines, TME, Eibach, BNE, Koni suspension, iPd sways, iPd panhard, Cherry Turbos upper/lower braces, forged BBS RG-Rs, Michelin Pilot SS, ecodes, V90 bits.
Old 04-19-2018, 10:36 AM   #113
BR1CKHOUS3
Issa Brick
BR1CKHOUS3's Avatar
Thanks guys My roommate and I both came from pretty cluttered homes so we do our best to keep our place nice
Trying to keep myself on track for the show
