Just did a little experiment, by the looks of it. it works fine using my B20 coolant sender...
in degrees C. After degreasing it I rinsed it under the tap, leaving it pretty cold. As soon as I hooked it up to the cars battery, it read almost 15C. , which is plausible because of the tapwater temperature.
I took my wives hairdrayer (she?s out at the moment..) and held it at some 15 cm?s from the sensor still at the batteries ground connector, it steadilly went to just over 40. Again plausible for you would burn yourselve otherwise..
After some 10 minutes cooling down it?s at about 26c? and very slowly dropping. At this set up it?s not mounted so only cools down by air and sitting against a cool battery connector..
The temperature outside is at the moment 23c. so in the shade it says right now (I just went out again..) 20-21c.
By the looks of it this is accurate. Bassically the only critical temperatures are around 0C. but then again, one should use gauges like this only as a reminder and one has to use common sense in winter conditions. The red LED pops up at about 5C anyway...
So I will now make a decent bracket and hide it under the fender or the like (do not use a bumper..).
So no more searching for overpriced "ambient sensors" ..
