riseosiris
Modem Killa
- May 10, 2003
- Alameda, CA
Back from a long absence (sort of). I have used the LH 2.2 brains from a '86 240 B230F for an EFI conversion on my 1976 BMW 2002. All of the mechanical bits are BMW (intake, TB, Fuel Rail etc)
I've got it started and driving (goes like stink!). However, the M10 in the BMW would like a slightly higher idle than the 750 or so the computer wants to provide. I adjusted the TB stop to allow it around a 900rpm idle when warm and reset the TPS so it reads correctly. This works great, but when cold it still struggles a bit. Should the computer go to an elevated idle when cold (like say 1200 or so?), or after starting will it settle into normal "hot" idle? I'm trying to make sure the system is functioning properly before I start thinking of alternatives.
Thanks!
-Lloyd
Thanks!
-Lloyd
