fengler
- May 6, 2004
- In the land of boredom
what about the ECT?
why not thow in a set of STOCK greentop turbo injectors? instead ofd those nasty looking Ford injectors
maybe google the Ford partnumbers and see how much they flow (@3bar/min)
If it's anything higher then 305-315cc then this could be causing the rich running.
I had the same issue- and putting "greentops" back in helped, since I didnt have a high enough flowing AMM to match the ford injectors (at a max of 11 lbs boost). Still, there is a little cut out issue under boost, but that could be for me due to a crank sensor issue which I may not have fully repaired, or because my spark plugs might be blowing out
I have not cleaned the injectors yet- I will do so, and hopefully find another spare set- I do not remember what car they need to come off of though- I will let you know when I find out. I replaced my spark plugs today, and found all the old ones have a white glaze, with the exception of the one closest to the firewall, which is black, with soot or oil, I'm not sure right now. I may have a missfire issue to top the original, seeing as how I'm also getting backfiring.
