Old 01-05-2019, 01:45 AM   #676
Atom D&D
Atom D&D's Avatar
Originally Posted by M.H. Yount View Post
Gracias.
Kinda sketchy looking site. We’ll see.
Atom D&D is online now   Reply With Quote
Old 01-08-2019, 06:13 PM   #677
BJORNAGN
Originally Posted by Atom D&D View Post
Ordered a new shirt for show season this upcoming year. Seems to fit my build well.
I can relate!
BJORNAGN is offline   Reply With Quote
Old 01-09-2019, 08:05 PM   #678
stick70
All the gauges
stick70's Avatar
I like those heater tubes, mine will have to be something similar. The nipple behind the head on my car is behind the firewall, didn't have time to tackle that during the install.
stick70 is online now   Reply With Quote
Old 01-09-2019, 09:36 PM   #679
Atom D&D
Atom D&D's Avatar
I went to Pick n Pull and just started pulling hard heater lines off random cars. Toyotas are stainless and have some decent long radius and short radius bends in them. They are a little short though, so you’d need a few.
Old 01-11-2019, 11:05 PM   #680
Atom D&D
Atom D&D's Avatar
Taking a break from engine stuff for a bit. Just working on a timing belt cover and then back on the interior.
Started by drawing the pulley positions and belt routing in CAD first. I was going to put the grille hexagons in the cover, but it looked too busy.
Then I cut the outside shape (flipped for front and back) out of MDF and sealed the MDF with BIN primer. Don’t know what’s in that stuff, but it dries fast and seals MDF quickly.
I wanted some bumps where the pulleys are even though it doesn’t “need” them. The back plates are made out of HDPE cause resins don’t stick to it.
Then I made an HDPE ring that will act as the step to make the two halves fit together. There’s clay in the corners as a fillet and the whole mold is sprayed with PVA mold release.
I took some acrylic rod pieces, sharpened them and placed them where the bolt holes in the head are.
I did two layers carbon and one layer of fiberglass with a middle layer of baltek mat in the back part to aid rigidity. Then vacuum bagged it.
Pro tip: if you want the weave of loose carbon to hold it’s shape when you’re cutting a template spray it with Super77 3M spray glue lightly.
Then demolding
Two halves fit together
Test fitting
Now I just need to fill voids, paint and finalize.
Old 01-12-2019, 02:35 AM   #681
Vol242vo
Vol242vo's Avatar
Killer, bummer the right cam gear cover didn’t line up as well as the other side damn it.
Derek - 1980 242
Old 01-12-2019, 09:51 AM   #682
M.H. Yount
M.H. Yount's Avatar
Paint will solve that.
Old 01-12-2019, 11:33 AM   #683
Atom D&D
Atom D&D's Avatar
Yeah, I’m just gonna paint this thing black probably.
Old 01-12-2019, 04:40 PM   #684
Shifted
On the Hill
Shifted's Avatar
I see eyes and a crooked smile...
He built my Bose 901s all by himself...
Doing something because you enjoy it is a must in life.
Originally Posted by ME II View Post
Without mistakes there is no learning.
"The mountain streams that rush on by/Show the fish a-jumpin' and reflect the open sky/The fresh clean smell of the pines/Symbol of unchanging times/All around this sacred land/Strangely, though, I've found my way/Right here I'm a-gonna stay/In this land" Tom Johnston/Doobie Brothers "Ukiah"
Lifeboat for the plankwalkers/otherwise disenfranchised.
Shifted is offline   Reply With Quote
Old 01-12-2019, 11:57 PM   #685
Vol242vo
Vol242vo's Avatar
What if you exposed the gears by cutting out the centers and paint them the same color as the block? I love the CF.
Old 01-13-2019, 10:06 AM   #686
Atom D&D
Atom D&D's Avatar
They aren’t really “gears”. Just two flat plates since dual VVT.
Old 01-13-2019, 10:34 AM   #687
doucheNozzle
doucheNozzle's Avatar
Could dress them up though
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
Old 01-13-2019, 05:25 PM   #688
Atom D&D
Atom D&D's Avatar
Took some time on a brisk Seattle morning to let my buddy do some drone photos
Old 01-13-2019, 11:39 PM   #689
Vol242vo
Vol242vo's Avatar
Let’s see those drone pics! There’s more of your buddy than your beautiful wagon...
Old 01-14-2019, 12:55 AM   #690
Atom D&D
Atom D&D's Avatar
Gotta wait for him to edit everything and put a video together.
Old 01-14-2019, 01:37 AM   #691
Vol242vo
Vol242vo's Avatar
You’re such a tease.
Old 01-14-2019, 07:16 PM   #692
matt b
Nice! I love the covers, the CF works well against the rest of the engine.
matt b is online now   Reply With Quote
Old 01-20-2019, 02:23 PM   #693
Atom D&D
Atom D&D's Avatar
Some in-progress stuff.
Then I decided that instead of having a radio blank and a clock blank and rear defrost blank and fader blank, etc. that I’d just cover that part too. It’ll become a panel to relocate the idiot lights from the dash (more on that later) and put in digital boost gauge.
Because the Amazon firewall is so close to the driver there’s not enough room to push the E30 cluster as far back as it is in an E30. What I’m going to do is pull the clear plastic face off the front, trim off the idiot light panel across the bottom, relocate those to the center stack, make individual bezels for the four dials (to look sort of aviation style) and have each bezel have it’s own acrylic face.
Also won an auction for a used Nardi from Japan. Now I need to track down an adapter hub.
Old 01-20-2019, 07:11 PM   #694
matt b
Website says you need Hub kit: 4370.95.0604, for the 86 BMW steering column
Old 01-25-2019, 10:51 AM   #695
Atom D&D
Atom D&D's Avatar
Little further.
I’d kind of like to add a green tint to the numbers. I don’t know if I’m gonna take it that far though.
Old 01-25-2019, 10:54 AM   #696
M.H. Yount
M.H. Yount's Avatar
Maybe a little different needle/pointer color?
Old 01-25-2019, 06:49 PM   #697
Vol242vo
Vol242vo's Avatar
Beautiful cluster! Very aviation like...Ties in nicely with your timing belt cover.
Old 01-25-2019, 08:19 PM   #698
Shifted
On the Hill
Shifted's Avatar
Once again... F'k yeah!
Old 01-26-2019, 05:55 PM   #699
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
How are you driving the cluster?
Old 01-26-2019, 07:33 PM   #700
Atom D&D
Atom D&D's Avatar
Right now, all OEM, but after the swap,
Speedo sensor is in the diff.
Temp is a/OEM sensor piggybacked
Fuel is fuel
Tach driven by MS3 output
