Old 11-13-2013, 03:15 PM   #26
FattMatt805
juggalo
FattMatt805's Avatar
Originally Posted by claymore View Post
One turbo feeding a supercharger is compound charged, compounding means the second compressor compounds the boost out of the feed compressor.
i stand corrected, i could have sworn that it was a twincharged setup, did not know the turbo was feeding the SC
1998 V70 T5M, 245k 218WHP, 238TQ. 15.19@95mph
1996 855T *CRASHED*
1987 suzuki samurai, stock, rolled twice, removed antiroll bars, 30"AT
1977 F250. 460ci
1957 H.D. Sportster. Mothballed
FattMatt805 is offline   Reply With Quote
Old 11-13-2013, 03:35 PM   #27
claymore
Ok what about 3 cylinders feeding a 15g and the other two feeding a 12t? I'm not trolling, I just want ideas, of alternatives to something like a garrett gtx,
claymore is offline   Reply With Quote
Old 11-13-2013, 03:52 PM   #28
Duder
His Dudeness, El Duderino
Duder's Avatar
OP: the only real reason to do something like this is for a show car, like the '57 Chevy posted above, just to get attention.
As an actual, functional system it will suck. As others have mentioned each turbo would only be getting 1/5th of the available exhaust energy, once every two engine revolutions, which causes several problems. Not to mention you've got a whole lot of added weight and efficiency losses by mutliplying turbo x5. A really good modern turbo is only about 55% efficient as an overall machine...that is, you get 55% of the energy you put into it back out again as usable work. 5 small turbos are not 5 times as efficient as one large turbo, not even close. You'll have more energy losses through the turbines, bearing systems, and compressors and the engine will therefore be working much harder to produce the same power output as it would with one properly sized turbo.
Let's say you wanted to make 500 bhp (at the flywheel) from your 2.3L 5-cyl, nice round number right? That's 100hp per cylinder or 217 hp/L. You'd need something like 32 psi manifold pressure, or about 3.3 pressure ratio on a compressor map, to do so at sea level, with the system optimized and working really well. This is treating the turbo match as five individual 0.46L single-cylinder engines. The corrected mass flow rate through each compressor would end up being about 8 lb/min at 6000rpm on this engine.
Look at the compressor maps of small turbos available for sale and you'll see that none of them will be anywhere near optimal running at 8 lb/min and 3.3 PR. Taking the Garrett GT1241 as an example, it's peak efficiency is available at 8 lb/min but only up to about 2.7 pressure ratio. At 3.3 PR you'd be overspeeding the crap out of this little guy (like 300,000 rpm vs. 220,000 rpm speed limit). Overspeeding not only puts a tremendous strain on the turbo mechanically but makes it a really poor air compressor. Compressor efficiency will be terrible, intake air temps will be very high, and as a result the turbine will be working much harder, creating more backpressure and killing flow through the head (VE). As most people who have played around with turbos know, "turning up the boost" will only net you more power up to a point of diminishing returns with a particular turbo.
Taking that GT1241 down to a reasonable pressure ratio like 2.7:1 means that you'd be making about 24 psi intake manifold pressure. With a properly sized single turbo, that's about 430hp at the flywheel, and the compressor would be flowing about 36 lb/min. There are plenty of small-ish turbos that could do this all day long, without the need for the added complexity & weight of four more turbos, wastegates, charge plumbing, etc. The other advantage of a small single turbo would be that you could turn up the wick to 32 psi / 3.3 PR and make 500 flywheel hp, no problema. A GT3071R for example would be perfect for 500hp on this 2.3L.
It's true that a single small turbo will have less rotational intertia and need much less exhaust energy to spool up than a large one, and if you had a 460cc single (dirt bike for example) I'd say sure, go ahead and use a GT12 or equivalent and make something like 85hp. But multiplying that system by 5 just doesn't make much sense when the net effects will just be:
-lower peak hp potential
-increased backpressure
-increased charge air temps
-increased fuel consumption
-added weight
-5x the amount of crap to fail
vs. a properly sized single turbo system at the same power level.
Old 11-13-2013, 03:53 PM   #29
Orange_Crusader
Moard Bember
Orange_Crusader's Avatar
I was just thinking of doing it for ****s and giggles, as long as I could produce the same power as a normal big turbo, I don't need to research compound charging, my 850 is already compound charged.
...pics?
850 GLT RIP
Lead Sled 98R AWD
Originally Posted by jackbombay View Post
You're just jealous that you don't have a van to rape goats in, not that any of you can prove I raped a goat anyway.
Originally Posted by badvlvo View Post
And if the bolt is broken in there you have a problem and should consult a bottle of scotch.
Orange_Crusader is offline   Reply With Quote
Old 11-13-2013, 04:02 PM   #30
claymore
-added weight
Thank you, a sensible answer, it was just a thought, I'll stick to a gt2871 then
Old 11-13-2013, 04:04 PM   #31
claymore
Originally Posted by Orange_Crusader View Post
...pics?
Old 11-13-2013, 04:39 PM   #32
John V, outside agitator
Banned
Whay about cylinder one feeding a tiny little thing into cylinder 2 a slightly larher one and progressively bigger... Screwing around with perspective,, bigger as they get farther away...
what about you do it?
Old 11-13-2013, 04:50 PM   #33
Mueller
Mueller's Avatar
It was a legitimate question, tell me why it's a stupid idea.
http://www.owendevelopments.co.uk/ar...UAD_TURBO_KIT/
Call them and ask how many kits they sold or how far it went in development.
Old 11-13-2013, 04:55 PM   #34
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
now that would be some seriously funny escher-esque stuff there.
Megasquirt Tuning!
Old 11-13-2013, 05:06 PM   #35
Banned
Exactly. Turbos going up pipes cone-ing out one way and cone-ing down the other..
Anything in a desparete attempt at attention..
A plumbing version of this:
But probably more like this:
And end up like this:
Old 11-13-2013, 05:07 PM   #36
linuxman51
linuxman51's Avatar
so the result may be a bit post-modernist.. sounds plausible
Old 11-13-2013, 05:08 PM   #37
claymore
Brilliant
Old 11-13-2013, 05:10 PM   #38
Frankypoo
Frankypoo's Avatar
I once saw a rollcage made of pipes like that! Or so I tought, maybe I was wrong and it was his 4 turbos piping? It was an early 90 Escort, with home made 5 point harnesses made from regular seatbelts!
Francois
242 GT 1979
Cruze LS Turbo 2014
Sorento EX Turbo 2016
Frankypoo is offline   Reply With Quote
Old 11-13-2013, 05:16 PM   #39
golgothan
5000+ HP Club
golgothan's Avatar
I have seen PVC roll cages multiple times.
golgothan is offline   Reply With Quote
Old 11-13-2013, 05:23 PM   #40
Duder
Duder's Avatar
A black iron pipe roll cage gave Black Iron Racing its team name.
http://oppositelock.jalopnik.com/sch...ipe-1411428910
Old 11-13-2013, 05:58 PM   #41
CAPT_BLOTTO
#Crush It
CAPT_BLOTTO's Avatar
[IMG]http://i.huffpost.com/gen/647933/thumbs/s-03929_PO_ESCHER_07-large640.jpg?4[/
[IMG]http://wondersinthedark.files.wordpress.com/2012/04/stooges-1.jpg]
[IMG]http://cdn.static.ovimg.com/episode/304514.jpg]
Everyone once in a while JohnV posts a gem.
Hello My Glorious!
Old 11-13-2013, 06:55 PM   #42
mark244turbo
mark244turbo's Avatar
Here's a couple of pictures of my quad turbo setup... if you have questions, give me a call.
OK, OK, it's not mine. Please don't call.
http://www.worldcarfans.com/11310116...ly/lowphotos#2
mark244turbo is offline   Reply With Quote
Old 11-14-2013, 03:56 AM   #43
FattMatt805
juggalo
that is, you get 55% of the energy you put into it back out again as usable work. 5 small turbos are not 5 times as efficient as one large turbo.
simple math 55x5=275
10x5=500
275-500=-225
negative 225% efficiency!!! wooo!!!
Old 11-14-2013, 10:01 AM   #44
badvlvo
Bad for Babies
badvlvo's Avatar
Originally Posted by Dammit View Post
If 5 is good, surely 10 is better?
You could make the intake pipework out of Mc Donalds straws.
Mine goes to 11.
Bad idea. Way more work and hassle for no gain.
So there's a supercharger under that intake log?
Or is I just twin-inter cooled?
Old 11-14-2013, 10:07 AM   #45
atrokz
super cage design genius
atrokz's Avatar
That 850 looks like a whole lot of trouble for nothing.
'06 BMW E91 3.0 DD
91 945 SE - Modded the turbobrick way
98 BMW E36 2.8 - Wife's car
92 245 DL WAS NOT TO BE -RETURNED FOR ZERO SPACE
91 745T RIP
94 850 NA RIP
95 850R GONE
Rob Ford was Canadas greatest president
atrokz is offline   Reply With Quote
Old 11-14-2013, 10:25 AM   #46
grnmachine02
Indicating?
grnmachine02's Avatar
I would disagree. I assume this is op's car.
1990 745t- b230ft, ebay manifold, hy35, Microsquirt, t5 2jz and w58 eventually no engine, and a decent mold collection on the interior.
Rage boner achieved.
grnmachine02 is offline   Reply With Quote
Old 11-14-2013, 10:40 AM   #47
BDKR
Section 9
BDKR's Avatar
How much power are you trying to make that you'd make a comparo to a GTX?
Why not this?
http://www.atpturbo.com/mm5/merchant...egory_Code=TBN
For south of 400hp, that's killer bang for buck!
For all you Dijkstra fanboys:
Old 11-14-2013, 10:55 AM   #48
claymore
Why not this?
My front engine produces 430bhp, I was just after something similar for the rear one, but I'll just stick to what I have and run two compound charged engines.
Old 11-14-2013, 10:56 AM   #49
atrokz
atrokz's Avatar
Cool, but nothing you couldn't do with just a good turbo, a good tune, and supporting mods.
So I stand by my statement. It's interesting, and out of the box thinking, but what does it provide that hasn't been done before?
Old 11-14-2013, 11:00 AM   #50
claymore
Agreed, but then it would be like every other tuned 850, which is a bit difficult for attracting sponsorship, and cost wise my car has cost less than £2000 to buy and build. my friend has paid nearly that amount for just a turbo and still has less power (at the moment)
