Old 11-14-2013, 10:01 PM   #76
BassGuy
BassGuy's Avatar
I've got nuthin against 850s.
2003 Volvo XC70
1991 945GLE - 16v Wagon! (in pieces)
1990 245 - DD, Pepper-thing (car, wagon, boat, mobile) - K-cam'd and Dale-gear'd - now an actual fridge, probably
1987 760 Turbo Intercooler - dead 07/14/2011
Feedback Thread
BassGuy is offline   Reply With Quote
Old 11-14-2013, 10:46 PM   #77
Vmaxx
Vmaxx's Avatar
Originally Posted by BassGuy View Post
Do tell? And by tell I mean show pics?
http://volvospeed.com/vs_forum/topic...ber-a-850-t10/
¡Vivo! 850 T5 16T 019-Black Stone
JUNKED&PARTING
"That's why we drive old cars and try to act proud of it." -RSPi
pm me for batch of 850/X70 parts
Vmaxx is offline   Reply With Quote
Old 11-14-2013, 10:47 PM   #78
Default U R Do'in It Wrong
This is how it's done.
Old 11-14-2013, 11:06 PM   #79
centason
Knipex=welfare queen
centason's Avatar
Oh the pinks car I would rip my hood off for that.
Member: TBCCS
"People will believe a big lie sooner than a little one, and if you repeat it frequently enough, people will sooner or later believe it." -Walter Langer
Old 11-14-2013, 11:08 PM   #80
centason
centason's Avatar
And I'd keep the welded valve covers
Old 11-15-2013, 01:07 AM   #81
Hoggster
Hoggster's Avatar
Originally Posted by CAPT_BLOTTO View Post
I'm trying to figure out how all of this is going to be controlled/work.
It has been done before. Back when 850s were new someone put a second engine in the rear.
A LeMons team has a corolla/MR2 mash up with the front of the corolla welded to the back of the MR2. One engine has an automatic transmission and the other one has a stick shift. The ratios aren't even close to each other. It seems to work well, so using two identical engines and transmissions should be a whole lot better.
You can get a throttle synchronizer from a marine supply shop. Boat builders have been running dual and even triple engine setups forever.
Hoggster is offline   Reply With Quote
Old 11-15-2013, 01:27 AM   #82
Toyotahead
Toyotahead's Avatar
Originally Posted by Duder View Post
A black iron pipe roll cage gave Black Iron Racing its team name.
http://oppositelock.jalopnik.com/sch...ipe-1411428910
My roll cage is black iron
The old man used it back when he was racing dirt track. Super thick hoop (.120 wall equiv), then everything else is .90 wall or so equiv. I'm adding in a ton more reinforcing points, but it'll keep it rigid and safe I believe (the gusseting and additional bracing will help too). Light? Not exactly. But inexpensive and effective.
Pimp tints, doof doof, and slorts.
Toyotahead is offline   Reply With Quote
Old 11-15-2013, 02:35 PM   #83
84 Blue 240
84 Blue 240's Avatar
Turbines don't like pulsed flow. The efficiency goes to crap. Having single cylinders on each turbine is a recipe for 30% turbine efficiency. Ideally you want 3 cylinders on a turbine/scroll. That optimizes blowdown pulse energy, eveness of flow to turbine, and reversion characteristics. That's the reason you see so many turbos 6s.
Originally Posted by manjiman View Post
I just wanted to know if the '87 740 turbo came with a differential? If so, which one?
1984 245 with Getrag Swap
84 Blue 240 is offline   Reply With Quote
Old 11-15-2013, 02:42 PM   #84
claymore
Originally Posted by 84 Blue 240 View Post
Turbines don't like pulsed flow. The efficiency goes to crap. Having single cylinders on each turbine is a recipe for 20% turbine efficiency. Ideally you want 3 cylinders on a turbine/scroll. That optimizes blowdown pulse energy, eveness of flow to turbine, and reversion characteristics. That's the reason you see so many turbos 6s.
Moved on from that idea now, but if you look at the Owen development setup, it looks like it has all 4 cylinders going into a collector, then splitting off to the 4 turbos, so that would probably even out the pulses. Anyway, it was just a thought that got flamed rather than a sensible discussion.
claymore is offline   Reply With Quote
Old 11-15-2013, 02:45 PM   #85
Ursan
الله الفول السوداني شطائر
Ursan's Avatar
how psi a stock can support?
I think this might be my chariot if I can jew the price down.
Old 11-15-2013, 03:03 PM   #86
zdriver123
zdriver123's Avatar
I'm Dissappointed in you Ken. Telling us that this is how its done. You can obviously see that he used a Fram oil filter.
zdriver123 is online now   Reply With Quote
Old 12-11-2013, 07:34 PM   #87
Turbeam
I do like radical thinking, whether it turns out to be practical and workable or not, it is what takes all kinds of developments in completely new directions.
I'd agree, feeding a turbocharger into a supercharger is indeed compound charging providing there is a pressure ratio higher than 1 across both at any time. There is no difference in doing this than doing the same thing by feeding one turbo into another.
The twin engine arrangement is also something that has been done many times on everything from rallycross Minis to Pikes Peak twin Ottinger-engined VW Sciroccos.
In the UK it isn't legal to have both engines running at the same time on a road car though.
This can actually be very straightforward on a FWD car, and using second hand parts/ donor vehicle not at all expensive. It would likely cost more to get the extra power out of the second engine than to do the whole rest of the conversion if it is done skilled DIY style.
Reliable.... of course. 2 gearboxes, 2 differentials and 4 driveshafts acting on 4 tyres, a fair bit more total car weight, but also twice as much power to push it along.... or looking at it another way, each engine only has just over half of the cars weight to shift.
As already mentioned, a manual gearbox in the front and an auto behind seems to work well to allow for speed differential, but 2 manuals can also work if the linking is done well.
I've even seen one case where the driver could apply more throttle to the rear engine to help kill understeer in corners by using a seperate additional rear hand throttle!
It should certainly accelerate quickly, but the down side is the extra weight generating higher lateral loading on the tyres in corners..... to the point that it could actually be quicker overall to build an ultra-light car with only one engine?
It would certainly be interesting and fun to drive though!
Turbeam is offline   Reply With Quote
Old 12-11-2013, 07:54 PM   #88
lummert
lummert's Avatar
Start with 5 of these in series and tell us the result.
http://www.ebay.com/itm/New-Electric...-/141107987228
Five times zero still equals zero.
Old 12-12-2013, 03:48 AM   #89
claymore
This is the donor car as of yesterday
Old 12-12-2013, 10:09 PM   #90
PRVersion
regretting name change
PRVersion's Avatar
Originally Posted by claymore View Post
my 850 is already compound charged.
what, do you have 2 cylinders running a small turbo, and 3 running a bigger one?
Ok what about 3 cylinders feeding a 15g and the other two feeding a 12t? I'm not trolling, I just want ideas, of alternatives to something like a garrett gtx,
never mind.
PRVersion wins.
accelerate til the last possible moment, then accelerate more...
PRVersion is offline   Reply With Quote
Old 12-12-2013, 11:12 PM   #91
Ursan
Ursan's Avatar
Old 12-13-2013, 12:49 PM   #92
claymore
never mind.
Yep, quote posts off the first page, things have moved on since then.
Old 12-14-2013, 07:53 PM   #93
buerckner
Love your work!
buerckner is offline   Reply With Quote
Old 12-15-2013, 02:37 PM   #94
claymore
Originally Posted by buerckner View Post
Love your work!
Thank you
Old 04-05-2014, 11:11 AM   #95
claymore
Just an update:
Old 04-05-2014, 11:27 AM   #96
Jack
junkman
Jack's Avatar
WOW
I like where this is going
Old 04-05-2014, 02:45 PM   #97
Hoggster
Hoggster's Avatar
Nice. Its good to see someone doing something crazy like this. Don't come to your senses until your finished! Then you can drive us to crazy town with you. Really fast.
Old 04-05-2014, 04:40 PM   #98
GreatDaneShane
GreatDaneShane's Avatar
awwwwwww yiss
GreatDaneShane is offline   Reply With Quote
Old 04-05-2014, 05:51 PM   #99
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
OMG ten years later and I still get to use this!
Just replace twin with Pent.
Old 04-11-2014, 12:50 PM   #100
claymore
Needs lowering a bit, I wonder how I might do that
