Old 12-22-2018, 03:12 PM   #226
photoman327
photoman327's Avatar
Great Work Dan! this is has given me a jump start!
Old 12-22-2018, 08:35 PM   #227
B2fkb0
B2fkb0's Avatar
Originally Posted by thismachine13 View Post
One ding from the tarmac and the nuts won't want to spin off the knackered threads.
I plan to saw the excess off. The pics are deceiving, this wonít be a problem (itís not my first performance exhaust). Thanks for your concern though!
83 242 turbo Gert
http://forums.turbobricks.com/showthread.php?t=318066
98 V70r Black (Pepper)
00 V70r Laser Blue (Lazarus)
98 v70r Saffron (Saff)
01 c70 coupe black (Shadow)
04 s60r Silver
04 v70xc Nautic
Sold:93 245 Silver,98v70xc Lucy, 96 855r Casper,
99s70t5m Panther, 98 v70xc Olive, 98v70r RN/m58 swapped 426 silver - Thor, 98v70r DynoRay CaR, 94 854 NA Turquoise, 06 s40t5m, 06 s60 t5a, 01 v70t5a
Totaled, parted, crushed: 96 855r Vader
B2fkb0 is offline   Reply With Quote
Old 12-22-2018, 08:39 PM   #228
B2fkb0
B2fkb0's Avatar
Thanks Greg! Iíve moved to the interior again to swap out the fan box with a 93 unit.
Hereís the newer unit;
Old 12-23-2018, 02:41 AM   #229
B2fkb0
B2fkb0's Avatar
Had to take some stuff apart and painstakingly label everything!
The ac condenser in the new unit is original but sound. Someone ran dye through the system and this has no leak! I cleaned it thoroughly and I’m running it!
Old 12-23-2018, 02:44 AM   #230
B2fkb0
B2fkb0's Avatar
Old 12-23-2018, 02:46 AM   #231
B2fkb0
B2fkb0's Avatar
Old 12-23-2018, 02:47 AM   #232
B2fkb0
B2fkb0's Avatar
Detailed and cleaned a lot of equipment! Added two switches!
Old 12-31-2018, 10:27 PM   #233
B2fkb0
B2fkb0's Avatar
So I sourced a 92 ac system from my friend Ian! Included the newer firewall pan for the evaporator lines, switch, wiring and relay, lines, condensor, pusher efan and wires, evaporator, compressor and mounts!
Old 12-31-2018, 10:34 PM   #234
B2fkb0
B2fkb0's Avatar
Pulled a G80 locker from my old parts 944. Grabbed the 4:10 ring and pinion because...
Old 12-31-2018, 10:59 PM   #235
B2fkb0
B2fkb0's Avatar
Drilled and tapped the B21ft for a later knock sensor.
Old 01-01-2019, 12:30 PM   #236
nedc
Just went thru this whole thread- unbelievable attention to detail and great work. One question: do you have a regular 'job' and do you ever sleep? LOL
I know this build has taken place over almost three years, but it is a ton of work, plus you're also swapping engines, etc. on other cars at the same time.
Anyway...I'm impressed!
nedc is offline   Reply With Quote
Old 01-01-2019, 02:06 PM   #237
B2fkb0
B2fkb0's Avatar
Thank you! I want this build to be the best I can make it since it’s such a rare car. I do get sidetracked by other demands (car repairs for the family/friends, other projects, volunteering, etc). I appreciate your kind words as I get feeling I’m not doing enough at times! That said, as I look back at 2018, I rebuilt two p2 Volvo’s, a fishing boat and a 23’ camper! So the 242 was a bit neglected over the year. My goal now is to get it out of the garage by Spring of this year...
Old 01-01-2019, 04:24 PM   #238
The Full Banana
not yet good enough
The Full Banana's Avatar
Are you planning on using the 4.10 ring and pinion in this car? Assuming you want this to be a street car, I'd recommend not going any shorter than 3.73 if you're pairing it with a M46, M47, M90, getrag 265 or other similarly-geared transmission.
-Tom 1980 242 T5
Old 01-01-2019, 11:14 PM   #239
B2fkb0
B2fkb0's Avatar
You’re right! I’ve had several folks advise me not to run it as I’m running an M46 so will likely retain the original 3:73 gearset. I respect your knowledge and advice (and your build) thank you!
Old 01-02-2019, 12:15 PM   #240
The Full Banana
not yet good enough
Good call! I think the 3.73 is a great match for a mild b230f(+)t and m46 setup.
Good luck getting it finished up and getting it out on the road. You're really close.
