Old 09-20-2018, 11:33 AM   #276
Shifted
On the Hill
Shifted's Avatar
Originally Posted by madeRus View Post
what is a LS?
American/GM V-8. https://en.wikipedia.org/wiki/LS_bas...l-block_engine
He built my Bose 901s all by himself...
Doing something because you enjoy it is a must in life.
Originally Posted by ME II View Post
Without mistakes there is no learning.
"The mountain streams that rush on by/Show the fish a-jumpin' and reflect the open sky/The fresh clean smell of the pines/Symbol of unchanging times/All around this sacred land/Strangely, though, I've found my way/Right here I'm a-gonna stay/In this land" Tom Johnston/Doobie Brothers "Ukiah"
Lifeboat for the plankwalkers/otherwise disenfranchised.
Shifted is offline   Reply With Quote
Old 10-08-2018, 01:22 PM   #277
madeRus
madeRus's Avatar
bought 4 ignition coils from audi R8
did the oil supply to the turbine and the pressure sensor
madeRus is offline   Reply With Quote
Old 10-13-2018, 02:16 AM   #278
madeRus
madeRus's Avatar
They installed two Teal gates, made them into an exhaust system (they are more cheerful on the street, as they say, but I don’t want to make hell).
small corrugations left to weld in, welded into each pipe at the exit from the cylinder to the EGT sensors, made the first part of the exhaust after the turbine, welded the expansion tank cooling.
Old 10-13-2018, 02:17 AM   #279
madeRus
madeRus's Avatar
made release from gates
Old 10-13-2018, 03:16 AM   #280
moise
moise's Avatar
always good job
moise is offline   Reply With Quote
Old 10-14-2018, 03:10 AM   #281
madeRus
madeRus's Avatar
Originally Posted by moise View Post
always good job
Old 11-29-2018, 04:50 PM   #282
madeRus
madeRus's Avatar
They made a silencer (the back can was not welded yet), a vibrant resonator 90mm., A pipe and a corrugation 90mm.)
Stretched gasoline pipes and installed fuel filters (pipe fasteners and a unifying filter ramp made on CNC)
Almost installed fuel ramps under two rows of injectors
Brake caliper rear tried on)
Old 11-30-2018, 01:53 AM   #283
moise
moise's Avatar
i don't reconize your gearbox, what is it?
Old 11-30-2018, 02:19 AM   #284
madeRus
madeRus's Avatar
getrag 260
Old 11-30-2018, 02:24 AM   #285
moise
moise's Avatar
Old 11-30-2018, 02:38 AM   #286
madeRus
madeRus's Avatar
Old 12-05-2018, 02:45 PM   #287
madeRus
madeRus's Avatar
Made mounting ignition coils
candles came 9ki from the US
Old 12-05-2018, 02:49 PM   #288
moise
moise's Avatar
easy for found parts in russia?
Old 12-06-2018, 04:54 PM   #289
madeRus
madeRus's Avatar
Parts to buy is not a problem, but buying parts for a racing car is more difficult!
but the problem is only in time!
Old 12-07-2018, 05:31 AM   #290
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
ehm.. do want those brackets ! would buy a set ;)
/edit
i find these sparkplugs quite expensive...
Old 12-11-2018, 03:21 AM   #291
madeRus
madeRus's Avatar
/edit
I bought in Russia for $ 350
Old 12-11-2018, 04:49 AM   #292
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
The brackets, or the plugs?
Old 12-18-2018, 04:00 PM   #293
madeRus
madeRus's Avatar
spark plug
brackets hand make
Old 12-20-2018, 05:08 PM   #294
madeRus
madeRus's Avatar
Did all the brakes, fuel, started to do a cold inlet
Old 12-20-2018, 06:16 PM   #295
LC4CARL
Aero challenged
LC4CARL's Avatar
This build is inspiring! Wish I had half your skills.
Life begins at 10PSI.
Old 12-23-2018, 02:16 PM   #296
madeRus
madeRus's Avatar
thank! many skills are not mine! there are people in Russia who understand the improvements
Old 12-27-2018, 03:23 PM   #297
madeRus
madeRus's Avatar
made a tank for washer glass
Old 12-28-2018, 08:27 PM   #298
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
i find the coolant solution quite interesting.. would you mind telling us more about it?
Old 12-29-2018, 10:52 AM   #299
madeRus
madeRus's Avatar
This cooling is made on the basis of mazda rx7! I took the radiator from the evolution 3!
the main thing during reworking is to make air guide plates
I decided to do so due to the fact that the radiator will heat the intercooler!
Old 02-01-2019, 11:57 AM   #300
madeRus
madeRus's Avatar
Hello to all)
The build process is on! little things left!
then there will be an electrician and the first start of the engine)
I hope for a couple of months in time)
bought a hydraulic handbrake!
