Old 06-08-2017, 08:05 AM   #76
spruill242
spruill242's Avatar
Originally Posted by kingkong View Post
It is upside down. No access to the spark plugs.
They never had good access to the spark plugs. Yours is oriented correctly you just need to trim some of the meat in the flange between the ports. Bracing is 100% a must.
'90 Spec Miata.. The barbie car I never got as a kid.....
http://norfolkdustlessblasting.com/ ... Professional stripper...
Originally Posted by HiSPL View Post
I like to masturbate with a cheese grater.
spruill242 is offline   Reply With Quote
Old 06-09-2017, 12:37 AM   #77
Tuff240
240 Ninja
Tuff240's Avatar
You ever put a exhaust gasket on backwards? Doesn't line up with the ports. Same thing is happening with his flange being on backwards. You can't just cut the extra material off of the flange. It needs to be flipped and oriented properly.
-Patrick
Old 10-21-2017, 12:25 PM   #78
kingkong
kingkong's Avatar
Hi guys,
A bit of progress.
Engine block is done and in the car.
M90 has been modded on 3rd gear, and in the car, along with a 850R clutch kit.
Hydraulic clutch conversion is done and man what a pain it was.
Big ass ebay intercooler is bought, and will go in front of the radiator, which is staying in stock location + visco for now. If you want to have a laugh, go to WANTED sub forum and look for my post, looking for a 240 TIC shroud + bracket. I will end up with an electric water pump and electric fan. Much better for keeping temps low when sideways.
MS3x ECU bought.
Injectors dynamics 1000cc's are on the manifold.
Turbosmart Comp40 wastegate is on it's way.
Ebay turbo manifold has been rewelded the right way.
Turbo feed and return lines are done (AN4 and AN12).
Next up : making the exhaust. Basically 3in all the way with a big magnaflow under the boot. Screamer pipe on the side.
Chinese government won't let me access to my google photos account so i will upload them in a few days when i am back to my red wine and smelly cheese country.
Peace.
kingkong is offline   Reply With Quote
Old 10-22-2017, 04:56 AM   #79
Funkee
Funkee's Avatar
Nice project man. Too bad you didn't get to break egos this summer but still it looks promising and cant waiit to see it finished.
What are the rest of the plans for the car, exterior wise?
Old 10-22-2017, 11:31 AM   #80
kingkong
kingkong's Avatar
Thanks man.
Yeah well, work is taking the best part of my weeks, and i moved house this summer with the gf so the volvo had to wait a bit. I trashed the miata on the track instead, was good fun !
Rest of the plans are cut springs, ipd 25mm sway bars front and rear, and upgraded brake pads.
Exterior wise, i don't know to be honest. I wanted to go low, overfenders and big offset wheels, but i guess i am getting to old and mostly, i haven't got enough time to do the research on offsets and clearance etc like i used to.
Frankly i just wanna throw the thing sideways, be reliable, and hear all the good boost noises.
Coming from an obnoxious japanese car, i really want the sleeper look now.
So i guess, lowered and maybe widened OEM steelies will do, unless i find a great deal on here for the right sizes. Paint job is ****ty and will stay that way lol.
Old 10-22-2017, 11:53 AM   #81
okoye
okoye's Avatar
Hey advice on the 850 clutch kit is to throw it out as mine slips at 20-25 psi on a 50 trim. I'd go with a clutchnet 6 puck.
Old 10-22-2017, 01:05 PM   #82
kingkong
kingkong's Avatar
Thanks for the heads up. Boost will begin at 15psi though, won't see 30psi until i am sure everything else is going as it should.
Old 10-22-2017, 06:09 PM   #83
MrKrabs
MrKrabs's Avatar
Promising project !
T'es de oý en France ?
MrKrabs is offline   Reply With Quote
Old 10-23-2017, 08:03 AM   #84
Sweep
Looking good! I too had a Holset off a chap in Poland, ebay store but can't remember his name, that was also a crusty piece of turd.
Old 10-24-2017, 10:33 AM   #85
kingkong
kingkong's Avatar
Originally Posted by MrKrabs View Post
Promising project !
Lyon
@sweep : yeah my first one came from him too. Ebay shop is called something like dixall. Turbo was still good, no play whatsoever, but too rusty for the time i had to give it TLC.
Old 10-24-2017, 03:19 PM   #86
Sweep
Lyon
That's the one! Yeah mine seemed fine too, couldn't get it apart so sent it to a turbo specialist here, pretty much fell into bits.
Old 12-12-2018, 03:22 AM   #87
kingkong
kingkong's Avatar
Hi peeps.
Long time no post.
First : the car is running, and damn its running good.
Summary of the last year :
Finished the engine and wiring. Started as it should.
ECU panel with MS3x :
I immediately noticed that the clutch was spinning as soon as it got on boost.
Took the gearbox out, only to find a greasy flywheel and disc.
Cleaned everything, put the gearbox back in. Things got better. No slippage until 7-8 psi boost.
This is what it looked like :
Than i noticed i had oil eveywhere in the engine bay.
So changed all the gaskets i could (oil filler cap, oil dip stick, cam cover, etc).
Then when i started the car, i put on a smoke show as far as 3 blocks away.
Long story short, the engine block was getting some pressure and the only way out was the turbo. So it was eating oil like crazy.
Some mods later, and a real oil catch tank system, all is well in the world.
and gaawwwdaaaaamn it's fast. My wastegate can't seem to manage boost under 15psi, although i got a 7 psi spring in it but oh well. life is boring under 15psi anyway.
But the car is now dangerous. For real. I needs brakes and suspension really bad.
IPD bars are on their way, and i am still thinking about what shocks would suit my soon-to-be cut springs.
Long journey but damn it makes me smile every morning on my way to work
30psi i'm commin at ya
Old 12-12-2018, 11:46 AM   #88
JCol91
Macaracachimba
JCol91's Avatar
ya
So a greasy flywheel would cause this? I have a similar issue on my 945 but itís on stock boost.
JCol91 is offline   Reply With Quote
Old 12-12-2018, 12:06 PM   #89
kingkong
kingkong's Avatar
Yeah I could only drive the thing on partial throttle. Some told me it could be the grease parts are covered with from factory.
And also the fact that the rubber plug on the back of the head popped out at some point, making an oily mess on the gearbox and clutch assy
Old 12-13-2018, 02:06 PM   #90
JW240
All idiot, no savant
JW240's Avatar
Nice, sounds good! Feeling of a proper turbo that spools is unbeatable.
Happy the cause of clutch slip has been found.
Some Renault vans have good looking 7x17 steelies with 5x108 bolt pattern. Should give ample space for bigger brakes. Porsche Cayenne/VW Touareg Brembo brakes maybe? Massive calipers yet light, very nicely made stuff.
I'm very happy with spherical bearings for the big rubber bushings in the trailing arms (rear axle), 'hybrid' torque rods, kaplhenke quick steer roll correction spacers. Really transformed the way my 240 handles. Springs and shocks first ofc
240 | 1991 | 333K Km | B230F+T | Cosworth T3 60/63 | M90 | TrueTrack
Husaberg FE450 '12 mx/supermoto swapped
Old 12-14-2018, 11:55 AM   #91
MrKrabs
MrKrabs's Avatar
Nice work! Jealous of your turbo haha
+1 for JW240's advice, you can get CitroŽn C6 17" steelies which are 5x108 7x17 et 32 with 65.1mm center bore. All over Leboncoin and even brand new on tyre/rim websites in France. Mount 225/45/17's and it'll look stock with ~15mm spacers. I ran some for a while.
Old 12-14-2018, 02:11 PM   #92
JW240
JW240's Avatar
Yup those are nice too. Buddy of mine runs those and found a version that fits without spacers.
You can see the version that I found here, round holes: https://forums.tbforums.com/showpost...&postcount=208
Old 12-15-2018, 04:44 AM   #93
kingkong
kingkong's Avatar
Thanks for the advice and kind words guys !
About the brakes, before thinking about new calipers, i've always had good luck with brand new fluid and agressive pads. I am sure i can find that for a 240 as well. Will look at sweden shops for that. Today my problem is i can do only a pair of 4th gear pulls before the pedal gets spongy
About suspension : i looked into BNE quick steer spacers, and i am sold !
But first thing first : shocks and springs, then maybe bushings ? No use for fancy parts if all rubbers are on the edge of failure.
And once i get the good handling and ride height, i will look into widened steelies wheels.
Renault and Citroen wheels is a GREAT INFO. Thanks.
Old 01-05-2019, 09:47 AM   #94
kingkong
kingkong's Avatar
Hi guys,
I am more and more thinking of bitting the bullet and take the pistons out to gap the rings properly. I am now running 1bar boost, but the more i read, the more i realize that when i crank up the boost, i will inevitably have ring ends touch and bind.
What gap do you guys reckon i should have for stock B230FK pistons at 2bar boost on e85 ?
Here's what Wiseco have to say about it :
http://blog.wiseco.com/everything-yo...about-ring-gap
So for their pistons, they advise to gap at bore * 0.004 = 3.8 *0.004 = 0.0152 = 0.39mm.
Do you think I can use this ?
