Old 12-06-2018, 11:40 AM   #376
PromiseRing
We don't even like Volvos
PromiseRing's Avatar
Originally Posted by Cwazywazy View Post
So Camry girl didn't lie about hitting me, but she claimed that she successfully pulled out and then got hit by the Honda.
Dashcam FTW.
Dude I’m just now seeing this. It’s always a ****ing Camry.
I’ve watched the video like 3 times now and it still doesn’t make sense to me. Looks like 2 cars were coming the opposite direction and the Camry was attempting to make a right. After the first car passed, looks like the Camry just floored it and ran into the side of the accord
Feedback Thread
Current:
93' 244 m47
93' 245 m47
90' 744 AW70
94' M-Edition Miata, 93k
95' Camry auto, 246k
94' 945T AW71(L?)
93' Camry auto, 278k
Past:
80' 242gt m46
88' 245 m47
92' 940 turbo AW71
Bready is a joke of a mod
Old 12-11-2018, 03:27 PM   #377
Cwazywazy
Cwazywazy's Avatar
So, small update. I discovered that the adapter and banjo on the turbo oil feed were totally loose. And all the driveshaft bolts. All of em.
Tested my rust skills on the battery tray which I might not even use.
Current problem is that I can't get the pedal box out of the wagon. I undid all the bolts and linkages and got it to move a little but no more. Do I have to drop the column or something?
Also I'm outta zipties...
I don't know what I have
Old 12-12-2018, 01:51 PM   #378
MDVLN
Kapitän Klugscheißer
MDVLN's Avatar
RE: Pedal Box -
There are 2 bolts above/forward the brake pedal that hold a bracket and bushing to the steering column that need to be removed. Reference below pic, courtesy of Arn02.
Originally Posted by Arn02 View Post
Fiited the brake pedal and tossed the clutch.
Old 12-12-2018, 03:36 PM   #379
Cwazywazy
Cwazywazy's Avatar
Got the pedals out thanks to some vigorous use of a pry bar on the column.
Old 12-23-2018, 07:56 PM   #380
Cwazywazy
Cwazywazy's Avatar
New fuel pump. Looks like the diesel still includes a wire for it so I shouldn't have to run one, but I'll have to do wires for the speedo. Looks like I can use the diesel lines under the car too. Might have to shorten the tube cause I can't get it to seat all the way into the tank. Also gotta put a filter in somewhere. Heatshrink in the tank a good idea?
Old 12-23-2018, 08:25 PM   #381
Broke4speed
Broke4speed's Avatar
Most heat sink isn't really fuel-rated. It could break down and clog your pump filter/sock. Definitely look up the product you used and see though.
1984 B6304S/AW30-40 w/Poi-Shift.
Old 01-07-2019, 01:44 PM   #382
Cwazywazy
Cwazywazy's Avatar
So I pulled the fuel filter off the wagon for the banjo fitting and I could feel the element banging around inside and it was just a hunk of rust. Might be why the temporary engine blew up at 7psi in 2017.. Makes me wonder about replacing the current injectors.
And the banjo was rusted though and leaking so I had to get a new one anyway. I used a normal 240 filter mounted on the firewall because it seemed like the easiest way to do it. Got it all together only to find out I somehow made a hole in the return hardline. Fixed that and now there's a really small leak on the other end of the hardline.
Old 01-07-2019, 04:47 PM   #383
MrBrown
You like popsicles?
MrBrown's Avatar
You may not want the filter that close to the turbo down pipe. Just my opinion though. Hope you sort the leaks out though!! Doin work. Love it
GhettoFab build thrizzie
Old 01-07-2019, 11:19 PM   #384
Cwazywazy
Cwazywazy's Avatar
Downpipe is wrapped, not really worried about it.
I believe I have all the bare necessities in place for the motor to run, but when I turn the key to start nothing happens. I'm thinking it's due to the auto neutral safety. Anyone know, off the top of their head, how to bypass it?
EDIT: So manual cars have a loop connector to bypass the neutral safety. Moved that over from the wagon and still nothing.
Old 01-08-2019, 01:42 AM   #385
MrBrown
You like popsicles?
MrBrown's Avatar
Not enough battery juice?
Old 01-08-2019, 04:15 PM   #386
Cwazywazy
Cwazywazy's Avatar
It cranks fine now. Just had to move the starter wire on the firewall connector.
I have power to the coil but no spark at the coil. Pretty sure I got the wires the right way round.
Old 01-13-2019, 10:57 PM   #387
Cwazywazy
Cwazywazy's Avatar
What does this thingy do and do I need it? Connected to coil negative.
Old 01-14-2019, 12:01 PM   #388
MrBrown
You like popsicles?
MrBrown's Avatar
Where does it go from there? I don’t think that’s needed but someone may have rigged it to bypass another wire..?
Old 01-14-2019, 12:11 PM   #389
culberro
culberro's Avatar
Looks like a capacitor. Aftermarket noise surpression? Removing it shouldn’t cause any issues.
Old 01-14-2019, 03:50 PM   #390
bobxyz
bobxyz's Avatar
If that black wire comes from your ignition control box (Chrysler or EZK?), it should go to Terminal 1. The blue wires on #15 are +12volts, and red/white usually goes to tach.
Old 01-14-2019, 04:04 PM   #391
Cwazywazy
Cwazywazy's Avatar
I mean the white wire and gray box. Black wire was for the efan relay.
Old 01-14-2019, 04:21 PM   #392
bobxyz
bobxyz's Avatar
As culberro said, the gray box is probably a filter capacitor for ignition noise. You can unplug it and see if you get rpm-varying audio noise on the radio (once running).
Are you using the original power stage / ignition module? It would have been in prime crunch territory and may be dead now.
Old 01-14-2019, 04:52 PM   #393
Cwazywazy
Cwazywazy's Avatar
Ah, okay. Powerstage wiring harness got chewed up a bit by the battery but I patched it up and it should be good to go. Still need a new EZK box..
Old 01-15-2019, 03:23 PM   #394
bobxyz
bobxyz's Avatar
Why do you need a new EZK box? If it was mounted in the original orientation, connector on bottom, I think you can pour water all over it and the inside (and connector pins) will stay dry. There's a lip and groove on the box that keeps it dry unless water is going up hill. Maybe try a new ign module first?
Old 01-15-2019, 03:29 PM   #395
Cwazywazy
Cwazywazy's Avatar
I cleaned it up and reflowed some ugly solder joints but the hall sensor still isn't getting any power.
Old 01-15-2019, 07:39 PM   #396
Cwazywazy
Cwazywazy's Avatar
Intercooler is fairly beat up but nothing too concerning. Not bent or anything.
I don't think the battery's gonna work, which sucks since it's virtually brand new. I'm wondering if it's better (cheaper) to relocate the fat one or just buy a smaller one..
Old 01-15-2019, 08:47 PM   #397
bobxyz
bobxyz's Avatar
If you want to test the EZ117K box by itself, connect ground to pin 20, +12V to pin 6, and measure pin 4 which is power to hall sensor. Pin 4 should be just slightly less than your +12V voltage (roughly a 0.6V diode drop lower).
