Old 04-09-2017, 05:47 PM   #26
Mr.Borrie
The Sneaky F*ing Russian
Mr.Borrie's Avatar
Originally Posted by okoye View Post
put those meshies all around and lower it. I think some stock tail lights will go a long way to making this a lot better looking. Have you thought about turboing it?
I like the R 18" to be honest but lets see. I have thought about turboing it!
I also have never seen another except for mine, until I've seen this. I took mine out for some reason and never got it back in, it's on the shelf somewhere. I think it never worked, how does your work? It opens with the key on ignition, or?D24TIC, actually. Both from the VIN code "75" and the fact that D24TIC was only factory diesel in 780's, no D24T's, no D24's.
It seems like your car wa 167th Bertone ever made, considering the fact that VIN code "G" says it's 1986, which was first year of production...
I thought they all had IRS's back there!?
Someone tipped you correctly, at least regarding 1986 N/A diesels, not sure about TIC's, since I never had a TIC older than 1987, and that car had the same crossmember as B230's.
Your car, having received D24 N/A, might also have -1987 diesel crossmember, which would have driver side motor mount welded in, just as B234F does.
BTW, as for your sunroof woes, I'll bet you your motor is out of sync. I think I explained procedure a couple of times and there should be a how-to somewhere on Brickboards...
Great car, even in that condition. Good luck!
- Radio was switched with a second sunroof switch, hit that and it would open
- Nope the old 86 diesels had solid axle. same like the parts blue car had in the last post
- I will get back on the sunroof issue, i did some parting of the car i will post back later on
Originally Posted by Shifted View Post
Nice work Borris.
Thanks!
Old 04-10-2017, 11:34 AM   #27
Mr.Borrie
Mr.Borrie's Avatar
well look at that, just got this 945 LPT for free from my neighbor that I helped out a few times with his Volvo and Corvet.
Guess I'll go 8V after all :-)
Old 04-21-2017, 09:58 AM   #28
Mr.Borrie
Mr.Borrie's Avatar
First off i was cutting down the 940 loom to just the injection and ignition bits. About a whole garbagebag and the stuff left on the passenger seat did about all for the inside
With the 945 running on just the loom i want i was ready 2 pull the 780 engine to start the conversion.
Old 04-21-2017, 11:37 AM   #29
okoye
okoye's Avatar
Do you plan to give it a 16v head at some point?
Old 04-26-2017, 05:30 AM   #30
Mr.Borrie
Mr.Borrie's Avatar
Not any time soon. If it all works out like I have in my mind I can see myself dallying the **** out of this car. So I would need to keep it simple.
Old 05-03-2017, 04:08 AM   #31
Mr.Borrie
Mr.Borrie's Avatar
Cut out the diesel mount, pulled the engine out of the 945 , swaped over the enginemounts and trew in the B230!
Redblock + M90 everything!
Bye Polar
Old 05-03-2017, 05:37 AM   #32
Shifted
On the Hill
Shifted's Avatar
Borris you're a monster... nice fast work.
Everything good on that side?
He built my Bose 901s all by himself...
Doing something because you enjoy it is a must in life.
Originally Posted by ME II View Post
Without mistakes there is no learning.
"The mountain streams that rush on by/Show the fish a-jumpin' and reflect the open sky/The fresh clean smell of the pines/Symbol of unchanging times/All around this sacred land/Strangely, though, I've found my way/Right here I'm a-gonna stay/In this land" Tom Johnston/Doobie Brothers "Ukiah"
Lifeboat for the plankwalkers/otherwise disenfranchised.
Shifted is offline   Reply With Quote
Old 05-03-2017, 08:07 AM   #33
Mr.Borrie
Mr.Borrie's Avatar
Thanks, having that 945 show up did boost my agenda around this car. I like to keep my driveway clean of clunkers so that motivated me
Things are going well on this side, got a kid on the way and getting married in a week or so. exiting stuff.... I need to get my projects done!
Old 05-03-2017, 11:16 AM   #34
okoye
okoye's Avatar
You know you could have swapped the cross members? that way it all would for sure bolt up!
Old 05-03-2017, 12:07 PM   #35
Ursan
الله الفول السوداني شطائر
Ursan's Avatar
I was gonna say, but cutting & grinding is moar manly.
how psi a stock can support?
I think this might be my chariot if I can jew the price down.
Old 05-03-2017, 12:10 PM   #36
Mr.Borrie
Mr.Borrie's Avatar
I Already knew it would bolt Up, the frames are the same minus the welded mount. Volvo is cool like that
This
Old 05-04-2017, 09:47 PM   #37
Shifted
On the Hill
Shifted's Avatar
Congratulations Brother.
Old 05-08-2017, 12:51 PM   #38
Mr.Borrie
Mr.Borrie's Avatar
Thanks!
Spend a few hours in the trunk for the fuel-pump swap, i reused the old tank that i drained before. First off i changed the springs of the trunk, mine did not stayed open and the parts-car had a good set
Old unit:
Diesel VS petrol
945 unit in!
made start of the rewiring
Old 05-08-2017, 01:26 PM   #39
JPS
good job!
JPS is offline   Reply With Quote
Old 06-16-2017, 10:43 AM   #40
Mr.Borrie
Mr.Borrie's Avatar
Spend some good time on the wiring and resoldering the needes wires so i could ditch the big connector blocks.
ALso bought some spacers for the Pegs.
After all that was sorted i fixed the fuel lines using a filter setup from a Volvo 360 and now she runs!
Next up is getting a exhaust, and clean the flame trap as the block did leak some oil but i'm pretty sure its the flame trap
Old 06-16-2017, 10:55 AM   #41
JPS
cleaning the flame trap thing stopped at my b230FK the oil leaking to, maybe consider making a extra carterventilation? i did that to, and then it stopped smoking every time i let of the trotle en jumped right on again. oil consumption is a lot less now
Old 06-16-2017, 11:10 AM   #42
okoye
okoye's Avatar
Like a catch can? I'm having serious oil burning issues while sitting at a light.
Old 06-17-2017, 10:16 AM   #43
JPS
jup catch can is what i have to, when the oil filler cap is dancing at idle a catch can is a good idea!
Old 06-20-2017, 12:06 PM   #44
Mr.Borrie
Mr.Borrie's Avatar
yeah most of the oil is near the flametrap and intake and again near the oil filter on the other side.
Still hunting for an exhaust and looking for someone that is willing to weld on the 780.. i did not post pictues of that but lets say i need a new floorpanel
Old 08-17-2017, 03:02 AM   #45
Mr.Borrie
Mr.Borrie's Avatar
Replaced all the balljoints in the suspension and a bunch of standard stuff not worthty of photo's but needed to be done. I do have this cool video of of a forge dumpvalve i installed
Old 08-17-2017, 06:56 PM   #46
thegoldbrick
thegoldbrick's Avatar
wow thats nice. link for a chump who wants one too?
Car(s)
90 760 Turbo (HG DONE)
Roasted Head: http://imgur.com/a/x4uk8
91 940SE
Cut your springs in half, sell the other half, and profit again.
thegoldbrick is offline   Reply With Quote
Old 08-21-2017, 11:00 AM   #47
Ursan
Ursan's Avatar
Okay, why are so many people low voting this?
Old 08-25-2017, 03:59 PM   #48
emem1160
how did you adopt the dumpvalve to be used with the B230FT motor?
emem1160 is offline   Reply With Quote
Old 09-29-2017, 09:02 AM   #49
Mr.Borrie
Mr.Borrie's Avatar
Most off the conversion is done, just need to get the welding done and a few odds and ends in the electonics.
Now it was time to look for an interior. that stuff be expensive!
I have been in contact with allot of people but all the interiors where twice what i paid for this entire project.
I decided to go with my old 760 turbo seats (from a V90) when a friend asked me if i wanted to buy his 780 project.
Few months later i got my interior... plus another 780
Old 09-30-2017, 12:14 AM   #50
slow240
Home Schooled
slow240's Avatar
WHERE DO YOU KEEP FINDING 780 PARTS CARS!?!?!?!
I cant find any in the states, my 780 needs little bits of loving here and there.
I'll polish your face
