Old 01-04-2019, 10:54 AM   #1
550
Default The "never-getting-done" 16VT 242
So I believe I made mention of this in my past build thread for the "Back burner 242" which is now actually the junkyard shell 242 (I.e. it's crushed... bye ).
The old:(https://forums.tbforums.com/showthread.php?t=203720)
The new: (but also, very old) Got this on October 9th, 2011 and didn't do anything with it. Oops.
44946_544388515835_3152637_n by Joe Bieda, on Flickr
66286_544382877135_5211218_n by Joe Bieda, on Flickr
Joe Bieda
V.C.O.A. Midwest Chapter President.
1984 242 M46 GLT.
-Couple of things done to it
1998 S70 Auto.
-LONG history.
1983 242 M46
Check out http://JJFAB.net For your K24 CBV blanking plates and oil feed/return flanges!!
550 is offline   Reply With Quote
Old 01-04-2019, 11:04 AM   #2
550
Building the motor:
This process only took like 5 years. LOL
Got some Wiseco pistons, and Rods from RSI before they went away. >_<
11046498_967859930725_8887406315015322397_n_967859 930725 by Joe Bieda, on Flickr
11018112_967860694195_45130121530305269_n_96786069 4195 by Joe Bieda, on Flickr
10408916_967860754075_9096292800765256493_n_967860 754075 by Joe Bieda, on Flickr
22393_967860379825_5582007862628314088_n_967860379 825 by Joe Bieda, on Flickr
Mmm shiney
11060282_980355589325_2983472020368351273_n_980355 589325 by Joe Bieda, on Flickr
Also picked up a crackscraper:
11048666_938065294415_8840907878891550551_n_938065 294415 by Joe Bieda, on Flickr
11011999_991964819335_1918238854592295381_n_991964 819335 by Joe Bieda, on Flickr
16V head bought from Kenny:
11021122_938065269465_1082810492479998478_n_938065 269465 by Joe Bieda, on Flickr
11698549_980355569365_2480150721836965807_n_980355 569365 by Joe Bieda, on Flickr
Old 01-04-2019, 11:11 AM   #3
550
Had to get the old junky B21 out:
11870641_991964649675_6924203331160779012_n_991964 649675 by Joe Bieda, on Flickr
11873700_991964574825_7884807239324664088_n_991964 574825 by Joe Bieda, on Flickr
11061165_991964584805_5727107852993875090_n_991964 584805 by Joe Bieda, on Flickr
So dirty and sad looking.
11060880_991964514945_7155575238197298946_n_991964 514945 by Joe Bieda, on Flickr
As you can see there are some "bids" written on the windshield. The car sat for so long that people (friends) started making bids on the car and how much I would let it go for.
11026280_991964694585_6207671521702104607_n_991964 694585 by Joe Bieda, on Flickr
Moments before they were washed away:
11059732_991964395185_1650740910246727567_n_991964 395185 by Joe Bieda, on Flickr
11825752_991964415145_8830573311464743653_n_991964 415145 by Joe Bieda, on Flickr
Much better:
12299283_10100120216109695_3274445770355753761_n_1 0100120216109695 by Joe Bieda, on Flickr
Old 01-04-2019, 11:17 AM   #4
550
Now onto cleaning the engine bay up, and getting it welded:(This happened almost 3 years ago now. Then my Subaru blew up and that consumed all of my money/time/motivation/effort)
Untitled by Joe Bieda, on Flickr
Old 01-04-2019, 11:22 AM   #5
550
Fitting the motor and making the mounts:
Got my modified bell housing from Ben, I'm also using his adapter plate.
T5 Trans mounted up
Mounts made and tacked:
Aluminum es mi favorito
Old 01-04-2019, 11:25 AM   #6
550
We're almost updated to the current date/time will finish and bring us current in a little bit.
Old 01-05-2019, 11:37 AM   #7
Tfrasca
Tfrasca's Avatar
Cool project. Why'd you decide to mount it vertically?
Old 01-07-2019, 07:51 AM   #8
550
Mostly because it's a little different. Adds a little flair. In hindsight though, I would have had this car running (maybe lol) a little bit sooner had I just used OEM mounts. A big hold up I struggled with for a while was driveline angle and motor angle.
With the help of some friends providing some much needed motivation, we kinda just decided to do it and see what happens.
Unfortunately my next hurdle will be keeping motivation, and after that praying the guy who did the work on the block bores wasn't on crack when he did it :-)
Old 01-07-2019, 12:44 PM   #9
550
Engine bay painted:
The Infamous Nathan double injector manifold held up:
Also, going to be adding a steering quickener, kind of always wanted one so we'll see how it works out. 1:1.5
Pulled the windshield out:
Very annoyed with the T4 collector I got from Vibrant:
Also, cut a hole in the floor to get rid of a rusty spot in the floor:
Old 01-07-2019, 02:02 PM   #10
Tfrasca
Tfrasca's Avatar
I did the same thing on my car, and ended up making my engine mounts a little off center somehow. Pretty annoying to have to figure out those driveline angle problems.
Your build looks great.
Old 01-09-2019, 01:46 AM   #11
t8fanning
8v are still cool, right?
t8fanning's Avatar
Looks like you're using ARP main studs. What did you do to get the oil pump transfer tube to clear?
1982 242 Turbo.
Old 01-09-2019, 08:39 AM   #12
550
Thanks!! Trying to get it at least moveable by spring time. It's only money AMIRITE?!
That's a good question, it's been put together so long I don't even remember anymore. I feel like we shimmed the pump up (technically down). But it was really close, and it didn't seem to be a big issue at the time.
Are you having this issue now??
Old 01-09-2019, 10:21 AM   #13
t8fanning
t8fanning's Avatar
No, but I replaced the one stud with an arp bolt to get the clearance I needed.
