Old 03-11-2012, 12:57 AM   #101
smith_t240
Abnormally Aspirated
smith_t240's Avatar
It runs!!! Yeah, I know it's been a while, but that doesn't matter anymore.
It didn't start initially. Determined it was spark related, then started double guessing my wiring - car currently has LH2.2 with EZK. Used a 740 EZK harness, LH 2.2 NA harness (without modification so I can sell it later), and hacked up the old 240 turbo harness which has the coolant temp, oil press, starter, alternator, etc. wires in it. Turned out to be the junkyard powerstage. Swapped that and it fired right up.
The warning lights in the cluster aren't coming on when the key is in position II, except for the oil pressure light. Not really sure why at this point. Still have some work to do before its driveable: oil feed line to turbo broke (AN fitting), correct size accessory belts, need the correct temp switch for the e-fan so I can install it in the radiator hose and fill this thing with coolant, cut some more off the cold side intercooler pipe so it fits with the AMM, figure out the crackcase vent, put another half quart in the M46, need the wastegate bracket fabricated from 2fast242gt, then button up the front clip and go do some burnouts!!
Smith T.
83 244Ti white project car
07 S60R 6spd black the better DD
Originally Posted by Ktown_Brick View Post
I stubbed my toe while getting a beer this afternoon. I feel both your guy's pain. What a crappy day, ohh well, tomorrow can't get much worse for me
smith_t240 is offline   Reply With Quote
Old 03-11-2012, 05:27 AM   #102
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
Reasons why only your oil pressure light comes on are either due to a bad or disconnected exciter wire to the alternator, or there are issues either with the alternator itself or with the instrument cluster. If the voltage jumps up to 13.5 or so when you've accelerated to about 15 mph in 1st gear (around 2500 rpm or so), then it's either the wire or the cluster that has issues.
Anyway, cool that the car's running again.
-J
Old 03-11-2012, 10:21 AM   #103
550
Congrats!
Joe Bieda
V.C.O.A. Midwest Chapter President.
1984 242 M46 GLT.
-Couple of things done to it
1998 S70 Auto.
-LONG history.
1983 242 M46
Check out http://JJFAB.net For your K24 CBV blanking plates and oil feed/return flanges!!
550 is offline   Reply With Quote
Old 03-11-2012, 02:23 PM   #104
2fast242gt
Do you have a cobalt?
want another m46 for cheep for when you blow that one?
1983 242dl
*6.0 lq4 swaped* Build thread
Old 03-11-2012, 07:01 PM   #105
Beachee
Beachee's Avatar
Keep up the good work!
Any more pictures...looking good!
Beachee is offline   Reply With Quote
Old 03-11-2012, 07:26 PM   #106
The Full Banana
not yet good enough
The Full Banana's Avatar
Congrats! Looking forward to seeing this thing.
-Tom 1980 242 T5
Old 03-11-2012, 08:57 PM   #107
smith_t240
smith_t240's Avatar
I think we have two spares in the shed currently. Honestly, after this one blows I'll be looking for something a lot stronger. My 16 valve head is just sitting in the basement right now.
Any more pictures...lokking good!
Thanks. I keep forgetting to bring my camera with me. Next time!
The reason the dash warning lights were not working was because of the alternator ground. Got that figured out. Also found the correct belt sizes for the Denso 100A alternator and the PS with the non-AC bracket.
Need to replace the AN fitting that broke on the oil feed and modify the cold side pipe to work with the AMM. To-do list is getting short!
Old 03-18-2012, 02:22 PM   #108
brant
Rusting
brant's Avatar
We need more pictures
1971 145 S WHITE
1989 744T RED
1998 V70R-M BLACK This car sucks
2002 V70XC BLUE
brant is offline   Reply With Quote
Old 03-18-2012, 06:32 PM   #109
smith_t240
smith_t240's Avatar
It drives. Waiting on Hobbyist plates so I can legally drive it on the road (never thought my reason for not driving it would be waiting for plates).
Definitely need one of these:
Think I'll black out the headlight surrounds like I did here:
E-fan needs to be wired in, throttle cable has a small amount of play in it, and most importantly, it needs a MBC.
Schedule a weekend coming up to do all the rear suspension as I never did that with the car in the garage.
R brakes pulled quite a bit up front, but they've been sitting for a while and I'd like to get some miles on them.
Old 03-19-2012, 04:11 AM   #110
The Full Banana
not yet good enough
i want a ride when it comes down here!!!
Old 03-24-2012, 10:36 AM   #111
smith_t240
smith_t240's Avatar
Old 03-24-2012, 01:17 PM   #112
Beachee
Beachee's Avatar
Well, the lights are on..... :-)
Old 03-24-2012, 01:50 PM   #113
2fast242gt
sweet picture smithers
Old 03-24-2012, 01:50 PM   #114
2fast242gt
whoa look at this one!
Old 03-24-2012, 03:08 PM   #115
smith_t240
smith_t240's Avatar
Double love from Brian overheat score the bore, new block double bore - big ole gap, piston slap.
Old 04-27-2012, 02:07 AM   #116
The Full Banana
not yet good enough
i demand an update. i want to see this thing in milwaukee!
Old 04-28-2012, 08:27 PM   #117
smith_t240
smith_t240's Avatar
Old 04-28-2012, 08:29 PM   #118
wisturbo
wisturbo's Avatar
Smith, this is awesome news buddy! Let me know when you bring her down to Milwaukee, Tom and I want to seeeee it!
wisturbo is offline   Reply With Quote
Old 04-29-2012, 06:35 PM   #119
smith_t240
smith_t240's Avatar
Thanks, man! Parking on the street blows.
Boost was at around 5 psi but I'm guessing its more like 14 now after adjusting the waste gate. Need to get the calibrated gauge in there. Somehow I lost a rear caliper mounting bolt.
Traction sucks. It has 205 performance tires and an open diff. Both of which need to be addressed.
Current mods:
Squirter block with LH2.2 and 850T injectors
Ported 90+ with 16T, 3" dp (and thats all of the exhaust atm)
No radiator fan
iPd turbo cam
NPR not installed yet
R brakes up front with the rear limiting valves removed in the back
Only the front suspension is done right now,
Coilovers with Koni yellows
Camber plates
Ipd sway
Poly everywhere
Old 04-29-2012, 06:42 PM   #120
Fitzy
Fitzy's Avatar
Nice list, love the brakes! The rear suspension might take a little while for you to hit everything but it will be totally worth it.
What is the advantage of removing the limiting valves?
08 c30 2.0 MT
06 s60R MT - Dead
84 242 Ti 4spd - A work in progress...
Fitzy is offline   Reply With Quote
Old 04-29-2012, 09:20 PM   #121
smith_t240
smith_t240's Avatar
Thanks! Basically the front brakes are a lot more powerful now so the rears can be more powerful without the fear of them locking up too easily.
I'm looking for an 06-07 S60R. Any advice for me? Gotta be manual and like the aero kit.
Old 04-29-2012, 11:06 PM   #122
Fitzy
Fitzy's Avatar
06-07 is the way to go, they benefit from all of the improvements over the years such as the awd, minor motor updates and interior. Don't touch an 04/05 unless it is super cheap. Even now an 07 is still fairly expensive that is if you can find one with less than 60k on it AND manual.
Definitely give them a good test drive and at least peak under the car to see if there are any leaks. If you find out the slave cylinder is leaking (leak appears from a similar weep hole as a RMS leak would) don't go near it unless you want to basically shell out $1200+ and have the clutch replaced. Mine is still going strong on the original trans, clutch, shocks and angle gear with 118K so if you find a good one they can be reliable.
Old 05-11-2012, 08:21 PM   #123
The Full Banana
not yet good enough
when do i get a ride?
Old 07-15-2012, 07:58 PM   #124
smith_t240
smith_t240's Avatar
Hey I had a free weekend and got to do some wrenching! Brakes need to be bled more, but more importantly the m46 is getting stuck in 2nd gear and really pissing me off. Word on the street is I'm buying 2fast242's engine and t5 transmission to put in this car
Went on a short drive and it pissed out the coolant - radiator has a hole in it. Got into the red but oh well.
Jacked it up and replaced the rear suspension this weekend. This car now has poly bushings everywhere except the front trailing arm bushing. The rubber is decent there and I didn't feel like burning it out and going to buy another size wire wheel at Fleet Farm.
The rear trailing arm bushings may have been original, and they were in poor shape. The manual cars are much harder on this bushing and you could definitely hear the axle shifting back and forth. Torque rod bushings were worn badly as well.
Fire in the hole!
And done. Not a bad job, but ended up getting really, really dirty. There's some grease underneath, but this car is so clean with the factory undercoating and no rust.
Oh and Fitzy, I found an R. Love it. 3 cars is a lot to handle as the R has been distracting me from the 244 a little bit. Forgot how long it takes to wax a car, my God.
Old 07-15-2012, 09:08 PM   #125
doucheNozzle
doucheNozzle's Avatar
Ditch the rear sway or go with something much smaller
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
