Old 07-15-2012, 09:10 PM   #126
smith_t240
Abnormally Aspirated
smith_t240's Avatar
Going to weld the diff when I put the new engine in. If I don't like it after that I'll do something about it.
Smith T.
83 244Ti white project car
07 S60R 6spd black the better DD
Originally Posted by Ktown_Brick View Post
I stubbed my toe while getting a beer this afternoon. I feel both your guy's pain. What a crappy day, ohh well, tomorrow can't get much worse for me
smith_t240 is offline   Reply With Quote
Old 07-15-2012, 09:12 PM   #127
doucheNozzle
doucheNozzle's Avatar
It takes 10minutes to drop
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
Old 07-15-2012, 09:26 PM   #128
550
Yeah, Im ditching my 25mm too real soon... it's kinda weird and the car is just too tail happy.
Joe Bieda
V.C.O.A. Midwest Chapter President.
1984 242 M46 GLT.
-Couple of things done to it
1998 S70 Auto.
-LONG history.
1983 242 M46
Check out http://JJFAB.net For your K24 CBV blanking plates and oil feed/return flanges!!
550 is offline   Reply With Quote
Old 07-15-2012, 09:44 PM   #129
smith_t240
smith_t240's Avatar
Smaller or no bar Joe?
Old 07-15-2012, 11:54 PM   #130
wisturbo
wisturbo's Avatar
Looks like a ton of progress! I can't believe you're going to have that monster in the 244! Time to apply for a tire sponsor!
wisturbo is offline   Reply With Quote
Old 07-16-2012, 08:24 AM   #131
550
I'll be running my smaller one, I think it's a 19mm. I will also put the front in soon too probably. The 25 is great for kicking the rear out, but I already don't think it will be that hard with the 25MM. And if I go any stiffer on the rear springs ( I think they are 250's, with the shorter Bils Sports) it will become even more apparent that the rear is slidey.
And on another note, NICE progress!
Old 07-17-2012, 05:14 AM   #132
The Full Banana
not yet good enough
The Full Banana's Avatar
I'm running no rear bar now with 25mm front. I'm going to try a 19mm in there
car is fantastic as always, smith... kinda getting tired of saying it. :P
how nice your car is keeps me motivated to keep working so i can try to get mine at least somewhat close...
-Tom 1980 242 T5
Old 07-22-2012, 10:09 PM   #133
smith_t240
smith_t240's Avatar
Well, picked up a new engine for this car this weekend as most of you know. If not, you will recognize it soon enough. Needs a few little odds and ends, like an air filter that flew out of the back of the truck!
Needs to be broken in, so 1,000 miles or so. Planning to do this on LH 2.2 and then switch to ECMlink or MS.
Also bought a T5 trans. Need the driveshaft, ds adapter, and a shifter. Going to look into the electric speedo with it.
Old 07-23-2012, 01:36 AM   #134
The Full Banana
not yet good enough
win win win win win!!!!!!!! can't wait to see it
Old 07-23-2012, 07:20 AM   #135
550
I have heard the pro 5.0's are pretty smooth shifting wise.
Old 07-29-2012, 10:16 PM   #136
smith_t240
smith_t240's Avatar
Hmmmm, the next level . . .
Order a bunch of parts to get this thing running ASAP!
And some cosmetic changes. Got rid of the cracked trim under the windows. The 3M pin stripe remover wheel worked great. Also am going back to coffinhood. Don't care to shell out $250 for a flathood grille right now.
Thanks for the help this weekend Gabe & Tom! Good times.
Old 07-30-2012, 12:43 AM   #137
The Full Banana
not yet good enough
Had a blast working on this car this weekend! A couple pictures for the purpose of documentation... late into the evening, when we were all quite tired
Gabe (gilber33)
Old 07-30-2012, 01:38 AM   #138
Josh
i'd sell you one for 150 dollars less than that
Josh is offline   Reply With Quote
Old 07-30-2012, 01:46 AM   #139
The Full Banana
not yet good enough
idk if it was clear, but he needs the flathood grill for quad squares
Old 07-30-2012, 01:48 AM   #140
Josh
ohhh ok.
Old 08-02-2012, 11:00 PM   #141
The Full Banana
not yet good enough
DIRY?
Old 08-02-2012, 11:42 PM   #142
smith_t240
smith_t240's Avatar
Let's just say the UPS man will be sick of pulling in my driveway. Parts incoming! Can't work on it this weekend but next weekend should get some work done.
Tom, please recommend a set of rims for this car, 17 or 18. I like your style. Say 5x120 but I don't want to restrict you.
Old 08-02-2012, 11:51 PM   #143
wisturbo
wisturbo's Avatar
Smith, will you be at JJ on Sat?
Old 08-02-2012, 11:54 PM   #144
The Full Banana
not yet good enough
I'll do something thinking on it. I usually look at stuff for either 242 or 245, so I'll do some looking at 244's. What works well for each body is a littttttle bit different.
if its me, you know it's gonna be 5x120. i assume this isnt a big hurry, right?
Old 08-03-2012, 12:03 AM   #145
smith_t240
smith_t240's Avatar
Joel, I will be up north otherwise I would be there. . . well maybe I would be working on this car instead! But yeah. . .
Tom, get what you're saying. I think this is going to become a hurry sooner rather than later. Those 205s are not going to be what I want. Granted I have a 1k mile break in to suffer through.
Was thinking about a remote oil cooler set up today. Something like summit sells, but then could I mount the 240 turbo oil cooler sandwich plate to the remote filter base with a longer nipple and then have lines to the oil cooler?
Old 08-03-2012, 12:09 AM   #146
The Full Banana
not yet good enough
I was thinking more along the lines of... before the car drives vs. once the car is driving
about oil cooler stuff in conjunction with remote filter....
http://forums.turbobricks.com/showthread.php?t=236358
and all the way at the bottom...
http://personal.linkline.com/dbarton/B23FT.html
Old 08-03-2012, 12:12 AM   #147
The Full Banana
not yet good enough
these are allegedly quite good
http://www.summitracing.com/search/P...location-Kits/
Old 08-03-2012, 12:14 AM   #148
The Full Banana
not yet good enough
that seems pretty logical to me... only thing that comes to mind that would be an issue would be clearance around the holset. you would likely need to use 90deg ends on the remote filter base to clear the turbo
Old 08-03-2012, 07:11 AM   #149
550
DIRY, Yet.
Old 08-03-2012, 11:33 PM   #150
The Full Banana
not yet good enough
smith, fatty brake booster for $20 (http://forums.turbobricks.com/showthread.php?t=263306)
unless joe has that one for you
