Old 10-15-2012, 12:56 PM   #176
The Full Banana
not yet good enough
The Full Banana's Avatar
He hasn't driven it yet.
-Tom 1980 242 T5
Old 10-15-2012, 10:46 PM   #177
smith_t240
Abnormally Aspirated
smith_t240's Avatar
Originally Posted by blkaplan View Post
So did you end up running the slip yoke with the damper on it? Any clearance issues? Do you have any noise from the trans?
No, the slip yoke diameter was too big to fit with the cross member I'm using - one of Nathan's early prototypes I believe.
I'll let ya know about the noise when I figure out why this thing isn't running. So far it looks like it's never even fired on cyl 2.
Bought a new Aeromotive FPR and fuel pressure gauge to dial the fuel pressure in better. Might switch to different and smaller injectors, at least for the break in period.
Haven't worked on the car in quite some time, at least a month.
Smith T.
83 244Ti white project car
07 S60R 6spd black the better DD
Originally Posted by Ktown_Brick View Post
I stubbed my toe while getting a beer this afternoon. I feel both your guy's pain. What a crappy day, ohh well, tomorrow can't get much worse for me
smith_t240 is offline   Reply With Quote
Old 10-16-2012, 12:13 AM   #178
The Full Banana
not yet good enough
I'm proclaiming a mini-meet in a few weeks to get life breathed into that thing. joe is coming. and we can abduct justus too.
Old 10-17-2012, 03:56 AM   #179
2fast242gt
Do you have a cobalt?
its a yoshifab x member and get it running!
1983 242dl
*6.0 lq4 swaped* Build thread
Old 11-12-2012, 11:26 AM   #180
The Full Banana
not yet good enough
Old 11-25-2012, 08:37 PM   #181
smith_t240
smith_t240's Avatar
So I've been avoiding this car a bit. Got it running nicely after replacing the broken fuel pressure gauge and dialing that in. However, the coolant was running into the oil pan at a beer bong like pace.
Old 11-25-2012, 08:55 PM   #182
smith_t240
smith_t240's Avatar
Nothing obvious as to why the head gasket is leaking, but the nuts near the intake side were slightly looser, which is where the oil drains are and that's where I'm thinking its leaking. Gonna check the head for flatness and go back to an Elring head gasket.
Also, if I go back to MLS I will definitely be using Hylomar.
Old 02-20-2013, 11:23 AM   #183
The Full Banana
not yet good enough
I'll give you $500 for the T5 swap.
Old 02-20-2013, 11:23 AM   #184
The Full Banana
not yet good enough
I'll give you $600 for the T5 swap.
Old 02-20-2013, 11:44 AM   #185
550
I'll give you 601 for the t5 swap.
Joe Bieda
V.C.O.A. Midwest Chapter President.
1984 242 M46 GLT.
-Couple of things done to it
1998 S70 Auto.
-LONG history.
1983 242 M46
Check out http://JJFAB.net For your K24 CBV blanking plates and oil feed/return flanges!!
550 is offline   Reply With Quote
Old 02-20-2013, 01:42 PM   #186
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
i give you a lol ;) problems with a redblock painted green and you ask for reason to fail ;)
Old 02-20-2013, 02:55 PM   #187
Beachee
Beachee's Avatar
I'll give you an advice. Take off the ARP , and replace them with OEM screws...
Beachee is offline   Reply With Quote
Old 02-20-2013, 03:06 PM   #188
smith_t240
smith_t240's Avatar
Pretty much . . .
Old 03-17-2013, 10:35 PM   #189
smith_t240
smith_t240's Avatar
Some progress over the past few months. Head is all back together with an Elring. Let's see if this seals better than the Cometic that was on it when I bought it.
New front end and wheels
Tucking some wires and cleaning up the engine bay. At this point it is looking very promising that this car will make its first appearance at MWM!
Better oil return
Old 03-17-2013, 10:46 PM   #190
The Full Banana
not yet good enough
I like this car a lot.
Also, I like how you coordinated your block and oil filter with your license plate.
Old 03-24-2013, 11:47 PM   #191
smith_t240
smith_t240's Avatar
Here's what it looks like now
I'm going to make a simple throttle cable bracket off the intake manifold here
Mmmm, camber. Really want to weld the plates in. Maybe if I have some time this summer.
So, the stock oil cooler thermostat assembly (sandwich plate) will work with the Holset, but I will need to take the compressor housing off of the turbo during oil changes.
For an oil cooler, I'm looking at a couple different spots, but am leaning towards inside/right behind the front bumper. Would need to cut some speed holes in the bumper and may even need a baby e-fan.
Also considered moving the radiator and intercooler over and using an up right oil cooler
It would be nice to mount an oil cooler right underneath the support below the radiator and intercooler, but may need to do away with the horn/core support to make room.
Old 03-25-2013, 12:09 AM   #192
2fast242gt
i took that support out for a while, the front isnt very sturdy without it. leaning on the front of your car working i could hear my grill crack :/. man that looks so clean...
Old 03-25-2013, 12:15 AM   #193
The Full Banana
not yet good enough
i was trying to figure out what changed to make it look so much better.
mann oil filter.
Old 03-25-2013, 10:23 AM   #194
doucheNozzle
doucheNozzle's Avatar
http://cl.ly/image/253S0L0S0h3r
That should give you an idea what it would look like. That's the stock 240/740 cooler.
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
Old 03-25-2013, 11:36 AM   #195
I would suggest leaving an 1/8" gap between that nut and the strut tower. You don't want to induce any bending loads into the strut assembly.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 03-25-2013, 02:03 PM   #196
smith_t240
smith_t240's Avatar
It should be right around there. I left the 24mm socket on the shock nut when installing the camber plates to make sure I could crank 'em down and loosen 'em up.
Old 03-25-2013, 02:57 PM   #197
jackpot
Old 04-13-2013, 08:36 PM   #198
smith_t240
smith_t240's Avatar
Old 04-13-2013, 08:37 PM   #199
smith_t240
smith_t240's Avatar
dp
Old 04-13-2013, 08:59 PM   #200
wisturbo
wisturbo's Avatar
Great progress bud! So, face down, ass up, huh bro?
wisturbo is offline   Reply With Quote
