Old 08-08-2017, 12:49 PM   #1
rokaskey
Default Lh 2.4 intermitent no signal to injectors
I have an intermitent problem with the lh2.4 injectors
One day it cranks over but cant grab. When checking the diagnostics (3rd stage) the injectors give no life
The next day it starts with no problem
What could be causing the issue?
Specs:
Lh 2.4
Ez-116k
B234f
rokaskey is offline   Reply With Quote
Old 08-08-2017, 12:54 PM   #2
KeizerBrickGuy
Sh*t pot stirrer
KeizerBrickGuy's Avatar
Check all grounds and connections for pin push out. I always start there when troubleshooting.
-Stephen
#mclovethesenuts
Old 08-08-2017, 01:14 PM   #3
Ryan_R
Check for spark. Power Stage or Cranks sensor. Injectors won't do anything until the spark happens. ECU provides ground. You should at least have 12V to the hot side of the injectors, if not radio suppression relay would be the next port of call.
-Ryan
Athens, OH
1987 245
1989 245 GL
1991 745 --Dog Waggin' 2.0
1995 945T -- Mildly modded
2011 XC90 3.2L AWD
https://people.ohio.edu/ridgely/e-code.htm
Ryan_R is offline   Reply With Quote
Old 08-08-2017, 01:29 PM   #4
Check wiring at relay. Worth swapping it over to the other side and using the fan relay for a while.
Injectors would still fire during OBD test with a spark malfunction.
Also worth cleaning and inspecting inlet manifold grounds as they are for the computer.
Old 08-09-2017, 01:05 PM   #5
nordmaschine
forced instruction
nordmaschine's Avatar
Cleaning grounds is always good and you should do it regardless, but the fact you can even get into DTM3 means they're, at least marginally, fine.
If the LED blinks rapildy as it's supposed to, but injectors stay silent, that usually means they're getting ground/trigger, but you can verify that with a test light between an injector connector - negative terminal and battery.
You probably lack injector +, which is usually due to pin-pullout at RSR connector. Or dead RSRelay in the first place. Pull it out and check the pins, are they level and all. If yes, swap the fan relay in, if not fix the connector. If they stay dead, work upstream from there - pull a diagram out and trace continuity all the way.
Jetronic is romantic.
Whiteblocks
